So using the Delta Calculator I got the printer going.
So using the Delta Calculator I got the printer going. For the last couple of days been trying to get prints accurate. I was using this formula:
" Here is my sample openscad object:
cube([100,2,2]));
If the length of the object is wrong, adjust DELTA_DIAGONAL_ROD:
new DELTA_DIAGONAL_ROD =
100 / measured_length * original DELTA_DIAGONAL_ROD"
(from the Minow blog)
When I used that formula and put in my new DDrod length my prints got shorter. So to fix this I shorten the rod length instead and it worked. My 100mm long stick now prints at 99.95mm. I might knock it down a little more to see if I can get it closer. First I’m going to do a cube or 2 in diff. locations and see what that does. Hopefully it won’t result in a broken window and trashed printer in the parking-lot.
I always thought DELTA_DIAGONAL_ROD was supposed to be adjusted if you were getting bowled or domed prints, and that it was used to adjust the ‘flatness’ of your travel across the bed.
The delta radius adjusts flatness. The diagonal rod length corrects xy error
I guess I should of posted the link to the blog: http://www.minow.blogspot.com/
Has anyone else used this formula and found it to be backwards? Instead of using the answer, 160.77, I would use 159.23. Maybe it’s a miss print or something.
@ekaggrat_singh_kalsi thanks for the correction; it’s been so long since I’ve actually had to tune a Delta.
@djC653 I agree mine came out the same way as you. Although I also get different measurements for X and Y so I also have something else wrong.
@Chris_Brent unequal x and y is due to unequal rod lengths. Remeasure the rods and try to get them equal
