solder mask rendering with eagle board import widget;
I recently picked up a laser to start lasering out solder masks and thus far i have discovered that this should definitely be done before holes are drilled. the widget renders everything fine except for solder pads around the vias. in eagle i have it set to create thermals and everything appears to be good. maybe i’m missing something. any advice would be appreciated.
