I just installed a Chimera and have everything working with the exception of the second stepper driving the extruder.
Running the latest firmware.
The steppers on E0 and E1 are identical, as are the stepper modules (DVR8825). Both pots on the modules have been tuned and putting out the same voltage.
What happens when I do a test extrude is the E0 extrudes normally but the E1 extrudes incredibly fast and the amount extruded is about 30.2x the length it should be.
I switched stepper motors and modules around but still get the same issue.
I have the exact same settings for E0 and E1 in the config so this really has me scratching my head. Anyone with insight able to help?
Thanks!
# Basic motion configuration default_feed_rate 8000 # Default speed (mm/minute) for G1/G2/G3 moves default_seek_rate 8000 # Default speed (mm/minute) for G0 moves mm_per_arc_segment 0.0 # Fixed length for line segments that divide arcs, 0 to disable mm_per_line_segment 5 # Cut lines into segments this size mm_max_arc_error 0.01 # The maximum error for line segments that divide arcs 0 to disable # note it is invalid for both the above be 0 # if both are used, will use largest segment length based on radiusArm solution configuration : Cartesian robot. Translates mm positions into stepper positions
See
arm_solution corexy
alpha_steps_per_mm 800 # Steps per mm for alpha ( X ) stepper
beta_steps_per_mm 800 # Steps per mm for beta ( Y ) stepper
gamma_steps_per_mm 6400 # Steps per mm for gamma ( Z ) stepperPlanner module configuration : Look-ahead and acceleration configuration
See
planner_queue_size 32 # DO NOT CHANGE THIS UNLESS YOU KNOW EXACTLY WHAT YOUR ARE DOING
acceleration 4000 # Acceleration in mm/second/second.
#z_acceleration 175 # Acceleration for Z only moves in mm/s^2, 0 uses acceleration which is the default. DO NOT SET ON A DELTA
junction_deviation 0.01 # See
#z_junction_deviation 0.0 # For Z only moves, -1 uses junction_deviation, zero disables junction_deviation on z moves DO NOT SET ON A DELTACartesian axis speed limits
x_axis_max_speed 30000 # Maximum speed in mm/min
y_axis_max_speed 30000 # Maximum speed in mm/min
z_axis_max_speed 175 # Maximum speed in mm/minStepper module configuration
Pins are defined as ports, and pin numbers, appending “!” to the number will invert a pin
See
alpha_step_pin 2.1 # Pin for alpha stepper step signal
alpha_dir_pin 0.11! # Pin for alpha stepper direction, add ‘!’ to reverse direction
alpha_en_pin nc # Pin for alpha enable pin
alpha_current 1.9 # X stepper motor current
alpha_max_rate 30000.0 # Maximum rate in mm/minbeta_step_pin 2.2 # Pin for beta stepper step signal
beta_dir_pin 0.20 # Pin for beta stepper direction, add ‘!’ to reverse direction
beta_en_pin nc # Pin for beta enable
beta_current 1.9 # Y stepper motor current
beta_max_rate 30000.0 # Maxmimum rate in mm/mingamma_step_pin 2.3 # Pin for gamma stepper step signal
gamma_dir_pin 0.22! # Pin for gamma stepper direction, add ‘!’ to reverse direction
gamma_en_pin nc # Pin for gamma enable
gamma_current 2.2 # Z stepper motor current
gamma_max_rate 175 # Maximum rate in mm/minbigfoot settings
motor_driver_control.alpha.enable true # alpha (X) is a TMC26X
motor_driver_control.alpha.designator X # A to set the settings
motor_driver_control.alpha.chip TMC2660 # chip name
motor_driver_control.alpha.current 1900 # current in milliamps
motor_driver_control.alpha.max_current 3000 # max current in milliamps
motor_driver_control.alpha.microsteps 128 # microsteps 256 max
motor_driver_control.alpha.alarm true # set to true means the error bits are checked
motor_driver_control.alpha.halt_on_alarm false # if set to true means ON_HALT is entered on any error bits being set
motor_driver_control.alpha.spi_channel 0 # SPI channel 1 is sdcard channel
motor_driver_control.alpha.spi_cs_pin 0.10 # SPI CS pin
#motor_driver_control.alpha.spi_frequency 100000 # SPI frequency
motor_driver_control.alpha.sense_resistor 100 # set the sense resistor used.
motor_driver_control.alpha.reg 00001,981C0,A0000,C000E,E0060 #motor_driver_control.beta.enable true # beta (Y) is a TMC26X
motor_driver_control.beta.designator Y # B to set the settings
motor_driver_control.beta.chip TMC2660 # chip name
motor_driver_control.beta.current 1900 # current in milliamps
motor_driver_control.beta.max_current 3000 # max current in milliamps
motor_driver_control.beta.microsteps 128 # microsteps 256 max
motor_driver_control.beta.alarm true # set to true means the error bits are checked
motor_driver_control.beta.halt_on_alarm false # if set to true means ON_HALT is entered on any error bits being set
motor_driver_control.beta.spi_channel 0 # SPI channel 1 is sdcard channel
motor_driver_control.beta.spi_cs_pin 0.19 # SPI CS pin DRV8711 requires inverted CS
#motor_driver_control.beta.spi_frequency 100000 # SPI frequency
motor_driver_control.beta.sense_resistor 100 # set the sense resistor used
motor_driver_control.beta.reg 00001,981C0,A0000,C000E,E0060 #motor_driver_control.gamma.enable true # gamma (Z) is a TMC26X
motor_driver_control.gamma.designator Z # G to set the settings
motor_driver_control.gamma.chip TMC2660 # chip name
motor_driver_control.gamma.current 2400 # current in milliamps
motor_driver_control.gamma.max_current 3000 # max current in milliamps
motor_driver_control.gamma.microsteps 128 # microsteps 256 max
motor_driver_control.gamma.alarm true # set to true means the error bits are checked
motor_driver_control.gamma.halt_on_alarm false # if set to true means ON_HALT is entered on any error bits being set
motor_driver_control.gamma.spi_channel 0 # SPI channel 1 is sdcard channel
motor_driver_control.gamma.spi_cs_pin 0.21 # SPI CS pin DRV8711 requires inverted CS
#motor_driver_control.gamma.spi_frequency 100000 # SPI frequency
motor_driver_control.gamma.sense_resistor 100 # set the sense resistor used
motor_driver_control.gamma.reg 00001,981C0,A0000,C000E,E0060 #Extruder module configuration
See
extruder.hotend.enable true # Whether to activate the extruder module at all. All configuration is ignored if false
extruder.hotend.steps_per_mm 173.9 # Steps per mm for extruder stepper
extruder.hotend.default_feed_rate 600 # Default rate ( mm/minute ) for moves where only the extruder moves
extruder.hotend.acceleration 500 # Acceleration for the stepper motor mm/sec²
extruder.hotend.max_speed 75 # Maximum speed in mm/s
extruder.hotend.step_pin 2.0 # Pin for extruder step signal
extruder.hotend.dir_pin 0.5! # Pin for extruder dir signal ( add ‘!’ to reverse direction )
extruder.hotend.en_pin 0.4 # Pin for extruder enable signalExtruder offset
extruder.hotend.x_offset 0 # X offset from origin in mm
extruder.hotend.y_offset 0 # Y offset from origin in mm
extruder.hotend.z_offset 0 # Z offset from origin in mmFirmware retract settings when using G10/G11, these are the defaults if not defined, must be defined for each extruder if not using the defaults
extruder.hotend.retract_length 1.5 # Retract length in mm
extruder.hotend.retract_feedrate 75 # Retract feedrate in mm/sec
extruder.hotend.retract_recover_length 0 # Additional length for recover
extruder.hotend.retract_recover_feedrate 10 # Recover feedrate in mm/sec (should be less than retract feedrate)
extruder.hotend.retract_zlift_length 0 # Z-lift on retract in mm, 0 disables
extruder.hotend.retract_zlift_feedrate 6000 # Z-lift feedrate in mm/min (Note mm/min NOT mm/sec)
#delta_current 1.0 # First extruder stepper motor currentSecond extruder module configuration
extruder.hotend2.enable true # Whether to activate the extruder module at all. All configuration is ignored if false
extruder.hotend2.steps_per_mm 173.9 # Steps per mm for extruder stepper
extruder.hotend2.default_feed_rate 600 # Default rate ( mm/minute ) for moves where only the extruder moves
extruder.hotend2.acceleration 500 # Acceleration for the stepper motor mm/sec²
extruder.hotend.2max_speed 75 # Maximum speed in mm/s
extruder.hotend2.step_pin 2.8 # Pin for extruder step signal
extruder.hotend2.dir_pin 2.13! # Pin for extruder dir signal ( add ‘!’ to reverse direction )
extruder.hotend2.en_pin 4.29 # Pin for extruder enable signalextruder.hotend2.x_offset 0 # x offset from origin in mm
extruder.hotend2.y_offset 25.0 # y offset from origin in mm
extruder.hotend2.z_offset 0 # z offset from origin in mm
#epsilon_current 1.0 # Second extruder stepper motor currentLaser module configuration
See
laser_module_enable false # Whether to activate the laser module at all
laser_module_pwm_pin 2.5 # This pin will be PWMed to control the laser.
# Only pins 2.0, 2.1, 2.2, 2.3, 2.4, 2.5, 1.18, 1.20, 1.21, 1.23, 1.24, 1.26, 3.25 and 3.26
# can
#laser_module_ttl_pin 1.30 # This pin turns on when the laser turns on, and off when the laser turns off.
#laser_module_maximum_power 1.0 # This is the maximum duty cycle that will be applied to the laser
#laser_module_minimum_power 0.0 # This is a value just below the minimum duty cycle that keeps the laser
# active without actually burning.
#laser_module_default_power 0.8 # This is the default laser power that will be used for cuts if a power has not been specified. The value is a scale between
# the maximum and minimum power levels specified above
#laser_module_pwm_period 20 # This sets the pwm frequency as the period in microsecondsTemperature control configuration
See
First hotend configuration
temperature_control.hotend.enable true # Whether to activate this ( “hotend” ) module at all.
temperature_control.hotend.thermistor_pin 0.24 # Pin for the thermistor to read
temperature_control.hotend.heater_pin 2.4 # Pin that controls the heater, set to nc if a readonly thermistor is being defined
temperature_control.hotend.thermistor Semitec # See
#temperature_control.hotend.beta 4066 # Or set the beta value
temperature_control.hotend.set_m_code 104 # M-code to set the temperature for this module
temperature_control.hotend.set_and_wait_m_code 109 # M-code to set-and-wait for this module
temperature_control.hotend.designator T # Designator letter for this module
temperature_control.hotend.max_temp 290 # Set maximum temperature - Will prevent heating above 300 by default
temperature_control.hotend.min_temp 0 # Set minimum temperature - Will prevent heating below if setSafety control is enabled by default and can be overidden here, the values show the defaults
See
#temperature_control.hotend.runaway_heating_timeout 900 # How long it can take to heat up, max is 2040 seconds.
#temperature_control.hotend.runaway_cooling_timeout 300 # How long it can take to cool down if temp is set lower, max is 2040 seconds
#temperature_control.hotend.runaway_range 20 # How far from the set temperature it can wander, max setting is 63°CPID configuration
See
temperature_control.hotend.p_factor 53.1 # P ( proportional ) factor
temperature_control.hotend.i_factor 3.439 # I ( integral ) factor
temperature_control.hotend.d_factor 205 # D ( derivative ) factor#temperature_control.hotend.max_pwm 64 # Max pwm, 64 is a good value if driving a 12v resistor with 24v.
Second hotend configuration
temperature_control.hotend2.enable true # Whether to activate this ( “hotend” ) module at all.
temperature_control.hotend2.thermistor_pin 0.25 # Pin for the thermistor to read
temperature_control.hotend2.heater_pin 2.5 # Pin that controls the heater
temperature_control.hotend2.thermistor Semitec # See
#temperature_control.hotend2.beta 4066 # or set the beta value
temperature_control.hotend2.set_m_code 104 # M-code to set the temperature for this module
temperature_control.hotend2.set_and_wait_m_code 109 # M-code to set-and-wait for this module
temperature_control.hotend2.designator T1 # Designator letter for this module
temperature_control.hotend2.max_temp 290 # Set maximum temperature - Will prevent heating above 300 by default
temperature_control.hotend2.min_temp 0 # Set minimum temperature - Will prevent heating below if settemperature_control.hotend2.p_factor 53.1 # P ( proportional ) factor
temperature_control.hotend2.i_factor 3.439 # I ( integral ) factor
temperature_control.hotend2.d_factor 205 # D ( derivative ) factor#temperature_control.hotend2.max_pwm 64 # Max pwm, 64 is a good value if driving a 12v resistor with 24v.
temperature_control.bed.enable true # Whether to activate this ( “hotend” ) module at all.
temperature_control.bed.thermistor_pin 0.23 # Pin for the thermistor to read
temperature_control.bed.heater_pin 2.7 # Pin that controls the heater
temperature_control.bed.thermistor EPCOS100K # See
#temperature_control.bed.beta 3974 # Or set the beta value
temperature_control.bed.set_m_code 140 # M-code to set the temperature for this module
temperature_control.bed.set_and_wait_m_code 190 # M-code to set-and-wait for this module
temperature_control.bed.designator B # Designator letter for this moduleBang-bang ( simplified ) control
Se
temperature_control.bed.bang_bang true # Set to true to use bang bang control rather than PID
temperature_control.bed.hysteresis 1.0 # Set to the temperature in degrees C to use as hysteresisSwitch modules
Se
Switch module for fan control
switch.fan.enable true # Enable this module
switch.fan.input_on_command M106 # Command that will turn this switch on
switch.fan.input_off_command M107 # Command that will turn this switch off
switch.fan.output_pin 1.22 # Pin this module controls
switch.fan.output_type pwm # PWM output settable with S parameter in the input_on_comand
#switch.fan.max_pwm 255 # Set max pwm for the pin default is 255#switch.misc.enable true # Enable this module
#switch.misc.input_on_command M42 # Command that will turn this switch on
#switch.misc.input_off_command M43 # Command that will turn this switch off
#switch.misc.output_pin 0.26 # Pin this module controls
#switch.misc.output_type pwm # Digital means this is just an on or off pinTemperatureswitch
See
Automatically toggle a switch at a specified temperature. Different ones of these may be defined to monitor different temperatures and switch different swithxes
Useful to turn on a fan or water pump to cool the hotend
#temperatureswitch.hotend.enable true #
#temperatureswitch.hotend.designator T # first character of the temperature control designator to use as the temperature sensor to monitor
#temperatureswitch.hotend.switch misc # select which switch to use, matches the name of the defined switch
#temperatureswitch.hotend.threshold_temp 60.0 # temperature to turn on (if rising) or off the switch
#temperatureswitch.hotend.heatup_poll 15 # poll heatup at 15 sec intervals
#temperatureswitch.hotend.cooldown_poll 60 # poll cooldown at 60 sec intervalsEndstops
See
endstops_enable true # The endstop module is enabled by default and can be disabled here
corexy_homing true # Set to true if homing on a hbot or corexy
alpha_min_endstop 1.24! # Pin to read min endstop, add a ! to invert if endstop is NO connected to ground
#alpha_max_endstop nc # Pin to read max endstop, uncomment this and comment the above if using max endstops
alpha_homing_direction home_to_min # Or set to home_to_max and set alpha_max and uncomment the alpha_max_endstop
alpha_min 0 # This gets loaded as the current position after homing when home_to_min is set
alpha_max 280 # This gets loaded as the current position after homing when home_to_max is set
beta_min_endstop 1.25! # Pin to read min endstop, add a ! to invert if endstop is NO connected to ground
#beta_max_endstop nc # Pin to read max endstop, uncomment this and comment the above if using max endstops
beta_homing_direction home_to_min # Or set to home_to_max and set alpha_max and uncomment the alpha_max_endstop
beta_min 8 # This gets loaded as the current position after homing when home_to_min is set
beta_max 300 # This gets loaded as the current position after homing when home_to_max is set
gamma_min_endstop 1.26! # Pin to read min endstop, add a ! to invert if endstop is NO connected to ground
#gamma_max_endstop nc # Pin to read max endstop, uncomment this and comment the above if using max endstops
gamma_homing_direction home_to_min # Or set to home_to_max and set alpha_max and uncomment the alpha_max_endstop
gamma_min 0 # This gets loaded as the current position after homing when home_to_min is set
gamma_max 400 # This gets loaded as the current position after homing when home_to_max is setalpha_max_travel 300 # Max travel in mm for alpha/X axis when homing
beta_max_travel 325 # Max travel in mm for beta/Y axis when homing
gamma_max_travel 400 # Max travel in mm for gamma/Z axis when homingOptional enable limit switches, actions will stop if any enabled limit switch is triggered
#alpha_limit_enable false # Set to true to enable X min and max limit switches
#beta_limit_enable false # Set to true to enable Y min and max limit switches
#gamma_limit_enable false # Set to true to enable Z min and max limit switchesfilament out detector
#filament_detector.enable true #
#filament_detector.encoder_pin 0.26 # must be interrupt enabled pin (0.26, 0.27, 0.28)
#filament_detector.seconds_per_check 2 # may need to be longer
#filament_detector.pulses_per_mm 1 .0 # will need to be tuned
#filament_detector.bulge_pin 0.27 # optional bulge detector switch and/or manual suspendEndstops home at their fast feedrate first, then once the endstop is found they home again at their slow feedrate for accuracy
alpha_fast_homing_rate_mm_s 50 # Alpha/X fast homing feedrate in mm/second
alpha_slow_homing_rate_mm_s 30 # Alpha/X slow homing feedrate in mm/second
beta_fast_homing_rate_mm_s 65 # Beta/Y fast homing feedrate in mm/second
beta_slow_homing_rate_mm_s 35 # Beta/Y slow homing feedrate in mm/second
gamma_fast_homing_rate_mm_s 8 # Gamma/Z fast homing feedrate in mm/second
gamma_slow_homing_rate_mm_s 2 # Gamma/Z slow homing feedrate in mm/secondalpha_homing_retract_mm 5 # Distance to retract from the endstop after it is hit for alpha/X
beta_homing_retract_mm 5 # Distance to retract from the endstop after it is hit for beta/Y
gamma_homing_retract_mm 5 # Distance to retract from the endstop after it is hit for gamma/ZOptional enable limit switches, actions will stop if any enabled limit switch is triggered (all are set for delta)
#gamma_limit_enable false # Set to true to enable Z min and max limit switchesOptional order in which axis will home, default is they all home at the same time,
If this is set it will force each axis to home one at a time in the specified order
homing_order XYZ # X axis followed by Y then Z last
#move_to_origin_after_home false # Move XY to 0,0 after homing
#endstop_debounce_count 100 # Uncomment if you get noise on your endstops, default is 100
#endstop_debounce_ms 1 # Uncomment if you get noise on your endstops, default is 1 millisecond debounce
#home_z_first true # Uncomment and set to true to home the Z first, otherwise Z homes after XYEnd of endstop config
Delete the above endstop section and uncomment next line and copy and edit Snippets/abc-endstop.config file to enable endstops for ABC axis
#include abc-endstop.config
Z-probe
See
#zprobe.enable false # Set to true to enable a zprobe
#zprobe.probe_pin 1.29 # Pin probe is attached to, if NC remove the !
#zprobe.slow_feedrate 5 # Mm/sec probe feed rate
#zprobe.debounce_count 100 # Set if noisy
#zprobe.fast_feedrate 100 # Move feedrate mm/sec
#zprobe.probe_height 5 # How much above bed to start probe#gamma_min_endstop nc # Normally 1.28. Change to nc to prevent conflict,
#Z Probe Codes
#M280 S3: Pin Down
#M280 S7: Pin Up
#M280 S8.4: Self Test
#M280 S10.6: Alarm Release
#M280 S5.5: Test ModeSwitch module for Z probe servo control
#switch.servo.enable true #
#switch.servo.input_on_command M280 S3.0 # M280 S7.5 would be midway
#switch.servo.input_off_command M280 S7.0 # same as M280 S0 0% duty cycle, effectively off
#switch.servo.output_pin 1.23 # must be a PWM capable pin
#switch.servo.output_type hwpwm # H/W pwm output settable with S parameter in the input_on_comand
#switch.servo.pwm_period_ms 20 # set period to 20ms (50Hz) default is 50HzLevelling strategy
Example for 3-point levelling strategy, see wiki documentation for other strategies
#leveling-strategy.three-point-leveling.enable false # a leveling strategy that probes three points to define a plane and keeps the Z parallel to that plane
leveling-strategy.three-point-leveling.point1 60.0,40.0 # the first probe point (x,y) optional may be defined with M557
#leveling-strategy.three-point-leveling.point2 60.0,250.0 # the second probe point (x,y)
#leveling-strategy.three-point-leveling.point3 250.0,145.0 # the third probe point (x,y)
#leveling-strategy.three-point-leveling.home_first true # home the XY axis before probing
#leveling-strategy.three-point-leveling.tolerance 0.03 # the probe tolerance in mm, anything less that this will be ignored, default is 0.03mm
#leveling-strategy.three-point-leveling.probe_offsets 0,0,0 # the probe offsets from nozzle, must be x,y,z, default is no offset
#leveling-strategy.three-point-leveling.save_plane true # set to true to allow the bed plane to be saved with M500 default is false#leveling-strategy.rectangular-grid.enable true # The strategy must be enabled in the config, as well as the zprobe module.
#leveling-strategy.rectangular-grid.x_size 270 # size of bed in the X axis
#leveling-strategy.rectangular-grid.y_size 290 # size of bed in the Y axis
#leveling-strategy.rectangular-grid.size 3 # The size of the grid, for example, 7 causes a 7x7 grid with 49 points.
# Must be an odd number.
#leveling-strategy.rectangular-grid.probe_offsets 0,0,0 # Optional probe offsets from the nozzle or tool head
#leveling-strategy.rectangular-grid.save false # If the saved grid is to be loaded on boot then this must be set to true
#leveling-strategy.rectangular-grid.initial_height 10 # Optionally an initial_height can be set that tell the intial probe
# where to stop the fast decent before it probes, this should be
# around 5-10mm above the bedPanel
See
Please find your panel on the wiki and copy/paste the right configuration here
panel.enable false # Set to true to enable the panel code
Example for reprap discount GLCD
on glcd EXP1 is to left and EXP2 is to right, pin 1 is bottom left, pin 2 is top left etc.
+5v is EXP1 pin 10, Gnd is EXP1 pin 9
#panel.lcd reprap_discount_glcd #
#panel.spi_channel 0 # SPI channel to use ; GLCD #EXP1 Pins 3,5 (MOSI, SCLK)
#panel.spi_cs_pin 0.16 # SPI chip select ; GLCD #EXP1 Pin 4
#panel.encoder_a_pin 3.25!^ # Encoder pin ; GLCD #EXP2 Pin 3
#panel.encoder_b_pin 3.26!^ # Encoder pin ; GLCD #EXP2 Pin 5
#panel.click_button_pin 1.30!^ # Click button ; GLCD #EXP1 Pin 2
#panel.buzz_pin 1.31 # Pin for buzzer ; GLCD #EXP1 Pin 1
#panel.back_button_pin 2.11!^ # Back button ; GLCD #EXP2 Pin 8
#panel.contrast 6panel.menu_offset 1 # Some panels will need 1 #here
#panel.alpha_jog_feedrate 6000 # X jogging feedrate in mm/min
#panel.beta_jog_feedrate 6000 # Y jogging feedrate in mm/min
#panel.gamma_jog_feedrate 200 # Z jogging feedrate in mm/min#panel.hotend_temperature 185 # Temp to set hotend when preheat is selected
#panel.bed_temperature 60 # Temp to set bed when preheat is selectedCustom menus : Example of a custom menu entry, which will show up in the Custom entry.
NOTE _ gets converted to space in the menu and commands, | is used to separate multiple commands
#custom_menu.power_on.enable true #
#custom_menu.power_on.name Power_on #
#custom_menu.power_on.command M80 ##custom_menu.power_off.enable true #
#custom_menu.power_off.name Power_off #
#custom_menu.power_off.command M81 #Network settings
See
#network.enable true # Enable the ethernet network services
#network.webserver.enable true # Enable the webserver
#network.telnet.enable true # Enable the telnet server
#network.ip_address auto # Use dhcp to get ip addressUncomment the 3 below to manually setup ip address
#network.ip_address 192.168.3.45 # The IP address
#network.ip_mask 255.255.255.0 # The ip mask
#network.ip_gateway 192.168.3.1 # The gateway address
#network.mac_override xx.xx.xx.xx.xx.xx # Override the mac address, only do this if you have a conflictSystem configuration
Serial communications configuration ( baud rate defaults to 9600 if undefined )
For communication over the UART port, not the USB/Serial port
uart0.baud_rate 115200 # Baud rate for the default hardware ( UART ) serial port
second_usb_serial_enable false # This enables a second USB serial port
#leds_disable true # Disable using leds after config loaded
#play_led_disable true # Disable the play ledKill button maybe assigned to a different pin, set to the onboard pin by default
See
kill_button_enable true # Set to true to enable a kill button
kill_button_pin 2.12 # Kill button pin. default is same as pause button 2.12 (2.11 is another good choice)#msd_disable false # Disable the MSD (USB SDCARD), see
#dfu_enable false # For linux developers, set to true to enable DFUAzteeg specific settings do not change
currentcontrol_module_enable false #
digipot_max_current 2.4 # max current
digipot_factor 103.0 # factor for converting current to digipot value
#51.0 for SD8825, SD6128, BSD4989
