Someone [Andy] completed a K40 Problem form but I do not see a corresponding post on this community.
The problem is stated in the form as:
I replaced a bad stepper motor with the only one I could find, and now if I cut a 25mm circle, it will cut a 25mm X 50mm oval. All of my “X” movement is doubled. Is there something i can change to fix this? Or do I need a new motor?
Andy:
Can you post your problem in this community so we can help you out.
- Why do you think your motor was bad?
- What motor was in your machine. Post picture of label.
- What motor did you put in your machine. Post picture of label.
- Did you replace the pulley or use the old one?
Community:
…Has anyone replaced a stock stepper?
…If so with what?
…Any help on Andy’s problem?
