Someone's seen this problem before...
Someone’s seen this problem before…
I’m fiddling with FSR auto-levelling and the endstops are mostly working correctly (there’s some fiddling with the pressure applied to the Z_Min, but the real oddity is:
If you G30 to start the process, it’s like the X and Y motors get twice the ticks that the Z motor does…the effector rapidly converges onto the Z tower. E-steps are equal, and everything else in the firmware appears to work fine…I’ve gone so far as to tell it it’s got a 10mm diameter build plate (in case it was shooting for an area on a big plate), and it still shoots for the moon.
Thoughts?
Lower your z travel speed. It sounds like the same problem I had implementing auto bed leveling.
That sounds…odd
Try G28 then G29 to auto level
I never use G30
Wait, you have a delta?
I do. (You haven’t seen the epic battles getting it to initially print? Where’ve ya been man!? :slight_smile: )
Lol, I am sorry, I realized that after I posted comments, I was trying to help but I don’t have any delta experience.
