Sometimes it is hard to admit that an animation does not get better with more oscillators. Again less was more for creating a consistent illusion. This time I invested a bit more time into the fine tuning. It turned out that oscillator ratios based on prime numbers do a pretty good job.
So, what do we see? The interference of 2 8 bit noise layers controlled by 7 oscillators. That is all. Please notice, that I did not move the z parameter of the 2D noise planes.
@Mark_Kriegsman data smoothing helps a lot to make the noise look even better and more fluid. Nearly no flickering edges / pixels anymore when using bigger scale values.
The camera is focussed, the distance between the leds and the diffusor (just paper) is approximately 1cm. 251 leds @ arround 80 fps.
I invite you to take the time and watch the video until the end –
I too appreciate the noise smoothing Mark posted. Great work Stephan, I am awaiting the delivery of a spectrum shield, just so I can start experimenting with all the ‘free’ stuff you’ve posted on here.
Have you considered routing some variables out to potentiometer knobs? This way you could tune some of the constants or values with a tactile control - could be cool for interactivity
Yes, at home I have a fader bank for that job. Here I used a little programm as GUI which sended the parameters linked to some sliders to the Teensy. It is way faster compared to compiling it hundert times. After I found the parameters I did not need the computer anymore.
Because I basically like the external physical control and my fader bank is not really elaborate I might get myself a fancy blinky midicontroller box for sexy realtime tactile control…
Very nice - elegant solution for prototyping
For MIDI controllers, I have a launchpad mini + korg nanokontrol 2. Both were pretty inexpensive and work wonderfully. The NanoKontrol is great as a bank of knobs and buttons, I think $40
