Jason_He
(Jason He)
Sorry, this is sort of a report from the K40 community. I probably should have posted here first.
If I wanted Laserweb to leave a sprue in a shape that I am cutting, how should I modify the shape in the SVG?
It will normally cut the outline of the shape, but my goal is to just leave about a millimeter that isn’t cut.
I have been using CorelDraw to create the SVG if that helps.
Tabs. This screenshot is from earlier in development, but the way to access it is still the same: https://plus.google.com/101442607030198502072/posts/T5yyw78gQV8
I posted an answer in the k40 list. I have been using corel for many years and know how to use it fairly well. PM me if you still have problems.
Jason_He
(Jason He)
4
Thank you both. I figured it out with your tips. I can’t believe the tabs were right there and I missed it all this time.
Cheers!
