(I’m asking for a friend) Lets say you want a solid state relay that’d take a 3.3v input to switch the load for the heater cartridge on a 12V hotend…any suggestions on what amperage it’d have to support?
I guess extra bonus points if it could handle 24 Volts.
To be honest, it probably be 5v trigger and 12v heater, but if I’m going through the trouble to create the design, it helps to accommodate the max and min possibilities.
The issue with most SSR input voltages is that while they will trigger at 3.3v, they require more current than most digital I/O pins can put out at that voltage without dropping the I/O voltage due to how they’re wired internally.
A switching transistor (eg: Darlington array or even a small FET) is all that is needed to get a decent output voltage.
