Standard spaced string, 48 pixels.  I can see what kind of image works better
Standard spaced string, 48 pixels. I can see what kind of image works better than others …
Is this with 30 LED/m tape or 60 LED/m tape?
This specific test is done with a standard 32 LED per meter string. Ultimately I’m building a more compressed display with all 48 pixels packed together within 30cm.
I should also point out that the software used to generate those images has since changed to a full color system (as opposed to having only 64 levels for each color.)
