Starting the chiller
Make sure you don’t get condensation forming on the laser tube
Watching this closely. I’m going to try something really similar to you. I hope you get good results.
@Sl33pydog just ordered a dew point sensor and will set the controller couple degrees above the dew point in the room
Hey brother shoot me a PM I have built a peltier cooler with 4 70 watt modules. I used the same exact water block from alibaba. Kinda funny. Anyways reach out. We are doing the same project!
I had a meanwell 35 amp 12 volt supply and it died… I cant figure it out. So I ended up using two ATX power supplies. Its a bit of a rats nest with the wiring, but it’s almost sorted out.
i ended up having to do 4 as well. 2 just wouldn’t keep up and I am using a ATX power supply as well. I get them from the computer graveyard at work.
