CescoAiel
(Cesco Aiel)
Starting to actually use LW4, and already ran in to a few smalll usability challenges in my workflow.
Hence two suggestions:
- Z adjust setting for each ‘document’ (so we can tell the laser inside the job itself to go out of focus)
- Pause job [before|after this ‘document’] (So we can make it pause at a desired point to - for instance - change lenses)
Good ideas, i really like the second one never thought of that before,
@CescoAiel first option exists on each operation (start height) That’s more flexible than each document.
The second one depends on firm, worth study
CescoAiel
(Cesco Aiel)
4
@Jorge_Robles really? I’ll have to look at that?! Didn’t notice that?
Go to settings, enable Z, enter your z homing default if you want.
When z stage is enabled, z start height will show up each operation
CescoAiel
(Cesco Aiel)
6
For the 2nd option: LW4 could pause sending gcode to the smoothie at the pause point until play is pressed again…
Yes, but we aim to grbl and tinyg too
i’m going to extend pre/post hooks anyway on gcode settings
They dont have pause commands?
could it not be a G code within the file?
Surely, but have to check the most generic way
CescoAiel
(Cesco Aiel)
12
@Jorge_Robles ah, it’s off by default in the FABkit settings profile
@CescoAiel the Z things are for the Emblaser they reverse the axis or somthing odd i believe so be careful
perhaps @Jorge_Robles knows more?
Hmm we unified that behavior. Z is heigth over the surface
CescoAiel
(Cesco Aiel)
15
I’ll test with it next weekend! GTG travel for work agin this week!
CescoAiel
(Cesco Aiel)
16
I’ve looked at the setting, and I see that I have some RTFM-ing to do on the Z axis stuff!
