Stepper direction on corexy and servo motion
Good Morning,
The smoothieboard is fantastic, and I have been making good use of it. I recently re-built a custom corexy printer and everything went swimmingly - until I went to home the axes. The motors are all wired in an identical manner, and I did not change the config file from when I shut it down to when I rebuilt it. The only change is that I put updated firmware on the Smoothieboard 5X (pulled from github on 6/19/2016).
My issue is that the X axis moves in the wrong direction. I have tried inverting the connectors on the board, and inverting the direction pin definitions in the config file (with all conceivable combinations) for both alpha and beta (my ‘x’ and ‘y’ motors). I am having flashbacks to working with the early Printrboards that had this sort of problem on the Y axis — any thoughts?
Config file for alpha and beta:
# Stepper module pins ( ports, and pin numbers, appending "!" to the number will invert a pin )
alpha_step_pin                               2.0              # Pin for alpha stepper step signal
alpha_dir_pin                                0.5              # Pin for alpha stepper direction
alpha_en_pin                                 0.4              # Pin for alpha enable pin
alpha_current                                1.5              # X stepper motor current
alpha_max_rate                               30000.0          # mm/min
beta_step_pin 2.1 # Pin for beta stepper step signal
beta_dir_pin 0.11 # Pin for beta stepper direction
beta_en_pin 0.10 # Pin for beta enable
beta_current 1.5 # Y stepper motor current
beta_max_rate 30000.0 # mm/min
Second issue - I have the servo module enabled, and I am able to get a partial response from the servo, but it is not working the way it should. If I pass M280 S10 to the board, the servo moves about 25 degrees from vertical (vertical would be S5). Any additional M280 commands will not produce a response. If I issue M281 I can hear the motor control release, and I can manually move the servo back to vertical, where it will respond to M280 S10 and move about 25 degrees again, but it will not respond to any other commands. I checked and double checked the power, and an arduino can move it no problem, so it has to be the signal. Maybe my pwm signal is not at the right period? The motor is an analog HD1501 MG power servo.
Config file for servo:
switch.servo.enable                            true             #
switch.servo.input_on_command                  M280             # M280 S7.5 would be midway
switch.servo.input_off_command                 M281             # same as M280 S0 0% duty cycle, effectively off
switch.servo.output_pin                        3.25             # must be a PWM capable pin
switch.servo.output_type                       hwpwm            # H/W pwm output settable with S parameter in the input_on_comand
#switch.servo.pwm_period_ms                    20               # set period to 20ms (50Hz) default is 50Hz
Any thoughts would be appreciated.
On issue 1 : does M119 report the endstops to work correctly ? Can we see your endstop config ? ( it’s generally a good idea to post the full config, with the collapse tags the interface mentions )
On issue 2 : You know Smoothie uses 0-100 not 0-255, correct ?
Cheers.
Hi arthurwolf,
Thanks for the quick response, unfortunately I am traveling this week so I am not by my smoothie or the PC that has the config - I’ll see if I can’t get the Mrs to email it so I can post it.
To answer your inquiries,1) yes - M119 reports endstops just fine - in fact I can home the machine and hit the end stop for x manually (as it is moving away from it) and it stops as if it is home - again will post the config when I get it or when I get home later this week.
2) Yes — the reason I posted is that I was using this servo setup previously and it worked just fine (S5 = vertical, S10 = 90 degrees+) — when I embedded the M280 command in gcode previously I had to put a G4 pause in to let the servo finish, but in the past I was able to issue single M280 commands that worked just fine.
Thanks again, I’ll post the config on here next time.
Hi authrurwolf,
Finally got back to the shop and figured I would get to the bottom of this. Grabbed the new edge firmware at github Smoothieware/FirmwareBin - loaded on the SD card per usual to flash the board. Revisited several older versions of config that I had used on this same setup to make sure I hadn’t missed something — now the Y axis is reversed (X homes correctly to min, Y tries to home to max, and manual control is reversed).
The servo is still unresponsive save the M280 S10 command, which still moves much less than it should and then is unresposive. Checked again, and arduino can move the servo the full range with the same data connection. I also tried a whole new data wire from 3.25 to the servo and got the same result.
Here is my full config:
# NOTE Lines must not exceed 132 characters
## Robot module configurations : general handling of movement G-codes and slicing into moves
default_feed_rate                            4000             # Default rate ( mm/minute ) for G1/G2/G3 moves
default_seek_rate                            4000             # Default rate ( mm/minute ) for G0 moves
mm_per_arc_segment                           0.5              # Fixed length for line segments that divide arcs 0 to disable
mm_max_arc_error                             0.01             # The maximum error for line segments that divide arcs 0 to disable
                                                              # note it is invalid for both the above be 0
                                                              # if both are used, will use largest segment length based on radius
#mm_per_line_segment                          5                # Lines can be cut into segments ( not usefull with cartesian
                                                              # coordinates robots ).
Arm solution configuration : Cartesian robot. Translates mm positions into stepper positions
arm_solution corexy
alpha_steps_per_mm 80 # Steps per mm for alpha stepper
beta_steps_per_mm 80 # Steps per mm for beta stepper
gamma_steps_per_mm 1829 # Steps per mm for gamma stepper
delta_steps_per_mm 270
epsilon_setps_per_mm 1829
Planner module configuration : Look-ahead and acceleration configuration
planner_queue_size 32 # DO NOT CHANGE THIS UNLESS YOU KNOW EXACTLY WHAT YOU ARE DOING
acceleration 3000 # Acceleration in mm/second/second.
#z_acceleration 500 # Acceleration for Z only moves in mm/s^2, 0 uses acceleration which is the default. DO NOT SET ON A DELTA
acceleration_ticks_per_second 1000 # Number of times per second the speed is updated
junction_deviation 0.05 # Similar to the old “max_jerk”, in millimeters,
# Lower values mean being more careful, higher values means being
# faster and have more jerk
#z_junction_deviation 0.0 # for Z only moves, -1 uses junction_deviation, zero disables junction_deviation on z moves DO NOT SET ON A DELTA
#minimum_planner_speed 0.0 # sets the minimum planner speed in mm/sec
Stepper module configuration
microseconds_per_step_pulse 1 # Duration of step pulses to stepper drivers, in microseconds
base_stepping_frequency 100000 # Base frequency for stepping
Cartesian axis speed limits
x_axis_max_speed 30000 # mm/min
y_axis_max_speed 30000 # mm/min
z_axis_max_speed 75 # mm/min
Stepper module pins ( ports, and pin numbers, appending “!” to the number will invert a pin )
alpha_current 1.0 # X stepper motor current
beta_current 1.0 # Y stepper motor current
gamma_step_pin 2.2 # Pin for gamma stepper step signal
gamma_dir_pin 0.20 # Pin for gamma stepper direction
gamma_en_pin 0.19 # Pin for gamma enable
gamma_current 2.0 # Z stepper motor current
gamma_max_rate 300.0 # mm/min
epsilon_current 2.0
epsilon_max_rate 300.0
System configuration
Serial communications configuration ( baud rate defaults to 9600 if undefined )
uart0.baud_rate 115200 # Baud rate for the default hardware serial port
second_usb_serial_enable false # This enables a second usb serial port (to have both pronterface
# and a terminal connected)
#leds_disable true # disable using leds after config loaded
#play_led_disable true # disable the play led
Kill button (used to be called pause) maybe assigned to a different pin, set to the onboard pin by default
kill_button_enable false # set to true to enable a kill button
#kill_button_pin 2.12 # kill button pin. default is same as pause button 2.12 (2.11 is another good choice)
#msd_disable false # disable the MSD (USB SDCARD) when set to true (needs special binary)
#dfu_enable false # for linux developers, set to true to enable DFU
#watchdog_timeout 10 # watchdog timeout in seconds, default is 10, set to 0 to disable the watchdog
Only needed on a smoothieboard
currentcontrol_module_enable true #
Extruder module configuration
extruder.hotend.enable false # Whether to activate the extruder module at all. All configuration is ignored if false
extruder.hotend.steps_per_mm 270 # Steps per mm for extruder stepper
extruder.hotend.default_feed_rate 600 # Default rate ( mm/minute ) for moves where only the extruder moves
extruder.hotend.acceleration 500 # Acceleration for the stepper motor mm/sec²
extruder.hotend.max_speed 50 # mm/s
extruder.hotend.step_pin 2.3 # Pin for extruder step signal
extruder.hotend.dir_pin 0.22 # Pin for extruder dir signal
extruder.hotend.en_pin 0.21 # Pin for extruder enable signal
extruder offset
extruder.hotend.x_offset 0 # x offset from origin in mm
extruder.hotend.y_offset 0 # y offset from origin in mm
extruder.hotend.z_offset 0 # z offset from origin in mm
firmware retract settings when using G10/G11, these are the defaults if not defined, must be defined for each extruder if not using the defaults
extruder.hotend.retract_length 3 # retract length in mm
extruder.hotend.retract_feedrate 45 # retract feedrate in mm/sec
extruder.hotend.retract_recover_length 0 # additional length for recover
extruder.hotend.retract_recover_feedrate 8 # recover feedrate in mm/sec (should be less than retract feedrate)
extruder.hotend.retract_zlift_length 0 # zlift on retract in mm, 0 disables
extruder.hotend.retract_zlift_feedrate 6000 # zlift feedrate in mm/min (Note mm/min NOT mm/sec)
delta_current 2.0 # First extruder stepper motor current
Second extruder module configuration
extruder.hotend2.enable false # Whether to activate the extruder module at all. All configuration is ignored if false
extruder.hotend2.steps_per_mm 140 # Steps per mm for extruder stepper
extruder.hotend2.default_feed_rate 600 # Default rate ( mm/minute ) for moves where only the extruder moves
extruder.hotend2.acceleration 500 # Acceleration for the stepper motor, as of 0.6, arbitrary ratio
extruder.hotend2.max_speed 50 # mm/s
extruder.hotend2.step_pin 2.8 # Pin for extruder step signal
extruder.hotend2.dir_pin 2.13 # Pin for extruder dir signal
extruder.hotend2.en_pin 4.29 # Pin for extruder enable signal
extruder.hotend2.x_offset 0 # x offset from origin in mm
extruder.hotend2.y_offset 25.0 # y offset from origin in mm
extruder.hotend2.z_offset 0 # z offset from origin in mm
#epsilon_current 1.5 # Second extruder stepper motor current
Laser module configuration
laser_module_enable false # Whether to activate the laser module at all. All configuration is
# ignored if false.
#laser_module_pin 2.5 # this pin will be PWMed to control the laser. Only P2.0 - P2.5, P1.18, P1.20, P1.21, P1.23, P1.24, P1.26, P3.25, P3.26
# can be used since laser requires hardware PWM
#laser_module_maximum_power 1.0 # this is the maximum duty cycle that will be applied to the laser
#laser_module_minimum_power 0.0 # This is a value just below the minimum duty cycle that keeps the laser
# active without actually burning.
#laser_module_default_power 0.8 # This is the default laser power that will be used for cuts if a power has not been specified. The value is a scale between
# the maximum and minimum power levels specified above
#laser_module_pwm_period 20 # this sets the pwm frequency as the period in microseconds
Temperature control configuration
First hotend configuration
temperature_control.hotend.enable false # Whether to activate this ( “hotend” ) module at all.
# All configuration is ignored if false.
temperature_control.hotend.thermistor_pin 0.23 # Pin for the thermistor to read
temperature_control.hotend.heater_pin 2.7 # Pin that controls the heater, set to nc if a readonly thermistor is being defined
temperature_control.hotend.thermistor EPCOS100K # see
#temperature_control.hotend.beta 4066 # or set the beta value
temperature_control.hotend.designator T #
#temperature_control.hotend.max_temp 300 # Set maximum temperature - Will prevent heating above 300 by default
#temperature_control.hotend.min_temp 0 # Set minimum temperature - Will prevent heating below if set
#temperature_control.hotend.p_factor 13.7 # permanently set the PID values after an auto pid
#temperature_control.hotend.i_factor 0.097 #
#temperature_control.hotend.d_factor 24 #
#temperature_control.hotend.max_pwm 64 # max pwm, 64 is a good value if driving a 12v resistor with 24v.
Second hotend configuration
#temperature_control.hotend2.enable false # Whether to activate this ( “hotend” ) module at all.
#temperature_control.hotend2.thermistor_pin 0.25 # Pin for the thermistor to read
#temperature_control.hotend2.heater_pin 1.23 # Pin that controls the heater
#temperature_control.hotend2.thermistor EPCOS100K # see
##temperature_control.hotend2.beta 4066 # or set the beta value
#temperature_control.hotend2.set_m_code 104 #
#temperature_control.hotend2.set_and_wait_m_code 109 #
#temperature_control.hotend2.designator T1 #
#temperature_control.hotend2.p_factor 13.7 # permanently set the PID values after an auto pid
#temperature_control.hotend2.i_factor 0.097 #
#temperature_control.hotend2.d_factor 24 #
#temperature_control.hotend2.max_pwm 64 # max pwm, 64 is a good value if driving a 12v resistor with 24v.
temperature_control.bed.enable false #
temperature_control.bed.thermistor_pin 0.24 #
temperature_control.bed.heater_pin 2.5 #
temperature_control.bed.thermistor Honeywell100K #
#temperature_control.bed.beta 3974 # or set the beta value
temperature_control.bed.set_m_code 140 #
temperature_control.bed.set_and_wait_m_code 190 #
temperature_control.bed.designator B #
#temperature_control.bed.bang_bang false # set to true to use bang bang control rather than PID
#temperature_control.bed.hysteresis 2.0 # set to the temperature in degrees C to use as hysteresis
# when using bang bang
Switch module for fan control
switch.fan.enable true #
switch.fan.input_on_command M106 #
switch.fan.input_off_command M107 #
switch.fan.output_pin 2.6 #
switch.fan.output_type pwm # pwm output settable with S parameter in the input_on_comand
#switch.fan.max_pwm 255 # set max pwm for the pin default is 255
Switch module for spindle control
#switch.spindle.enable false #
Temperatureswitch :
automatically toggle a switch at a specified temperature. Different ones of these may be defined to monitor different temperatures and switch different swithxes
useful to turn on a fan or water pump to cool the hotend
#temperatureswitch.hotend.enable false #
#temperatureswitch.hotend.designator T # first character of the temperature control designator to use as the temperature sensor to monitor
#temperatureswitch.hotend.switch misc # select which switch to use, matches the name of the defined switch
#temperatureswitch.hotend.threshold_temp 60.0 # temperature to turn on (if rising) or off the switch
#temperatureswitch.hotend.heatup_poll 15 # poll heatup at 15 sec intervals
#temperatureswitch.hotend.cooldown_poll 60 # poll cooldown at 60 sec intervals
Endstops
endstops_enable true # the endstop module is enabled by default and can be disabled here
corexy_homing true # set to true if homing on a hbot or corexy
alpha_min_endstop 1.24^ # add a ! to invert if endstop is NO connected to ground
alpha_max_endstop nc # NOTE set to nc if this is not installed
alpha_homing_direction home_to_min # or set to home_to_max and set alpha_max
alpha_min 0 # this gets loaded after homing when home_to_min is set
alpha_max 441 # this gets loaded after homing when home_to_max is set
beta_min_endstop 1.26^ #
beta_max_endstop nc #
beta_homing_direction home_to_min #
beta_min 0 #
beta_max 335 #
gamma_min_endstop 1.28^! #
gamma_max_endstop nc #
gamma_homing_direction home_to_min #
gamma_min 0 #
gamma_max 70 #
optional order in which axis will home, default is they all home at the same time,
if this is set it will force each axis to home one at a time in the specified order
#homing_order XYZ # x axis followed by y then z last
#move_to_origin_after_home false # move XY to 0,0 after homing
optional enable limit switches, actions will stop if any enabled limit switch is triggered
#alpha_limit_enable true # set to true to enable X min and max limit switches
#beta_limit_enable true # set to true to enable Y min and max limit switches
#gamma_limit_enable true # set to true to enable Z min and max limit switches
alpha_fast_homing_rate_mm_s 50 # feedrates in mm/second
beta_fast_homing_rate_mm_s 50 # "
gamma_fast_homing_rate_mm_s 3 # "
alpha_slow_homing_rate_mm_s 25 # "
beta_slow_homing_rate_mm_s 25 # "
gamma_slow_homing_rate_mm_s 2 # "
alpha_homing_retract_mm 5 # distance in mm
beta_homing_retract_mm 5 # "
gamma_homing_retract_mm 1 # "
#endstop_debounce_count 100 # uncomment if you get noise on your endstops, default is 100
Z-probe
zprobe.enable true # set to true to enable a zprobe
zprobe.probe_pin 1.28!^ # pin probe is attached to if NC remove the !
zprobe.slow_feedrate 2 # mm/sec probe feed rate
#zprobe.debounce_count 100 # set if noisy
zprobe.fast_feedrate 50 # move feedrate mm/sec
zprobe.probe_height 3 # how much above bed to start probe
#gamma_min_endstop 1.28!^ # normally 1.28. Change to nc to prevent conflict,
leveling-strategy.ZGrid-leveling.enable true # enable map level
leveling-strategy.ZGrid-leveling.bed_x 441
leveling-strategy.ZGrid-leveling.bed_y 335
leveling-strategy.ZGrid-leveling.bed_z 60
leveling-strategy.ZGrid-leveling.slow_feedrate 100
leveling-strategy.ZGrid-leveling.probe_offsets 19.6,4.4,0 # the probe offsets from nozzle, must be x,y,z, default is no offset
leveling-strategy.ZGrid-leveling.wait_for_probe true # Makes system wait for probe confirmation
leveling-strategy.ZGrid-leveling.rows 25 # X divisions (Default 5)
leveling-strategy.ZGrid-leveling.cols 25 # Y divisions (Default 5)
Panel
panel.enable false # set to true to enable the panel code
Example for reprap discount GLCD
on glcd EXP1 is to left and EXP2 is to right, pin 1 is bottom left, pin 2 is top left etc.
+5v is EXP1 pin 10, Gnd is EXP1 pin 9
#panel.lcd reprap_discount_glcd #
#panel.spi_channel 0 # spi channel to use ; GLCD EXP1 Pins 3,5 (MOSI, SCLK)
#panel.spi_cs_pin 0.16 # spi chip select ; GLCD EXP1 Pin 4
#panel.encoder_a_pin 3.25!^ # encoder pin ; GLCD EXP2 Pin 3
#panel.encoder_b_pin 3.26!^ # encoder pin ; GLCD EXP2 Pin 5
#panel.click_button_pin 1.30!^ # click button ; GLCD EXP1 Pin 2
#panel.buzz_pin 1.31 # pin for buzzer ; GLCD EXP1 Pin 1
#panel.back_button_pin 2.11!^ # back button ; GLCD EXP2 Pin 8
pins used with other panels
#panel.up_button_pin 0.1! # up button if used
#panel.down_button_pin 0.0! # down button if used
#panel.click_button_pin 0.18! # click button if used
panel.menu_offset 0 # some panels will need 1 here
panel.gamma_jog_feedrate 200 # z jogging feedrate in mm/min
panel.hotend_temperature 185 # temp to set hotend when preheat is selected
panel.bed_temperature 60 # temp to set bed when preheat is selected
Custom menus : Example of a custom menu entry, which will show up in the Custom entry.
NOTE _ gets converted to space in the menu and commands, | is used to separate multiple commands
custom_menu.power_on.name Power_on #
custom_menu.power_on.command M80 #
custom_menu.power_off.enable true #
custom_menu.power_off.name Power_off #
custom_menu.power_off.command M81 #
Network settings
network.enable false # enable the ethernet network services
network.webserver.enable true # enable the webserver
network.telnet.enable true # enable the telnet server
network.ip_address auto # use dhcp to get ip address
uncomment the 3 below to manually setup ip address
#network.ip_address 192.168.3.222 # the IP address
#network.ip_mask 255.255.255.0 # the ip mask
#network.ip_gateway 192.168.3.1 # the gateway address
#network.mac_override xx.xx.xx.xx.xx.xx # override the mac address, only do this if you have a conflict
Any advice would be much appreciated.
Thank you
Brian
Can you try starting from zero using the very latest firmware, and very latest configuration, editing only one config option at a time, and testing it each time ?
Hi authurwolf,
Sure - apologies for muddying the water — just flashed new firmware, and grabbed a new config file. I only changed the items that relate to the steppers and the endstops (and removed the links as my karma is too low to post them). Tried this:
  1. Wired the motors in an identical manner to what had previously worked - alpha, gamma and epsilon are oriented in the same manner (looking at the board from above, stepper connections on the top, BYGR from a NEMA17), beta is reversed (RGYB from the NEMA17). In this configuration, X direction moves fine, M119 shows ends stops are as expected, Z direction is fine. Y is reversed. Homing correctly goes to X zero, Y attempts to go to max (away from the endstop at Y=0) and will stop if I manually trip the Y endstop
  2. Wired the motors so that are all in the same connection to the smoothie alpha, beta, gamma and epsilon are all the same (BYGR from a NEMA 17). In this configuration, X direction moves fine, M119 shows ends stops are as expected, Z direction is fine and homes fine. X manual commands now move the print head in an opposite Y direction, Y manual commands give correct X axis movements. Homing has the print head attempt to go to Y max, then correctly goes to X min.
At this point I am thinking i could just swap the connections for the Y motor A coil and it should work, but I am perplexed why the identical mechanical setup is now behaving differently.
Here is the config file:
mm_per_arc_segment                           0.0              # Fixed length for line segments that divide arcs 0 to disable
arm_solution            corexy
# Arm solution configuration : Cartesian robot. Translates mm positions into stepper positions
epsilon_steps_per_mm            1829
z_axis_max_speed 300 # mm/min
gamma_current 1.5 # Z stepper motor current
epsilon_current 2.0
kill_button_enable true # set to true to enable a kill button
extruder.hotend.enable true # Whether to activate the extruder module at all. All configuration is ignored if false
extruder.hotend.steps_per_mm 140 # Steps per mm for extruder stepper
extruder offset
delta_current 1.5 # First extruder stepper motor current
extruder.hotend2.enable true # Whether to activate the extruder module at all. All configuration is ignored if false
# ignored if false.
temperature_control.hotend.enable true # Whether to activate this ( “hotend” ) module at all.
#temperature_control.hotend2.enable true # Whether to activate this ( “hotend” ) module at all.
temperature_control.bed.enable true #
#switch.misc.enable true #
#switch.misc.input_on_command M42 #
#switch.misc.input_off_command M43 #
#switch.misc.output_pin 2.4 #
#switch.misc.output_type digital # just an on or off pin
Temperatureswitch :
#temperatureswitch.hotend.enable true #
Endstops
alpha_max 200 # this gets loaded after homing when home_to_max is set
beta_min 0 #
beta_max 200 #
gamma_min 0 #
gamma_max 200 #
alpha_max_travel 500 # max travel in mm for alpha/X axis when homing
beta_max_travel 500 # max travel in mm for beta/Y axis when homing
gamma_max_travel 500 # max travel in mm for gamma/Z axis when homing
#alpha_limit_enable false # set to true to enable X min and max limit switches
#beta_limit_enable false # set to true to enable Y min and max limit switches
#gamma_limit_enable false # set to true to enable Z min and max limit switches
gamma_fast_homing_rate_mm_s 4 # "
Z-probe
zprobe.enable false # set to true to enable a zprobe
zprobe.slow_feedrate 5 # mm/sec probe feed rate
zprobe.fast_feedrate 100 # move feedrate mm/sec
zprobe.probe_height 5 # how much above bed to start probe
#gamma_min_endstop nc # normally 1.28. Change to nc to prevent conflict,
associated with zprobe the leveling strategy to use
#leveling-strategy.three-point-leveling.enable true # a leveling strategy that probes three points to define a plane and keeps the Z parallel to that plane
#leveling-strategy.three-point-leveling.point1 100.0,0.0 # the first probe point (x,y) optional may be defined with M557
#leveling-strategy.three-point-leveling.point2 200.0,200.0 # the second probe point (x,y)
#leveling-strategy.three-point-leveling.point3 0.0,200.0 # the third probe point (x,y)
#leveling-strategy.three-point-leveling.home_first true # home the XY axis before probing
#leveling-strategy.three-point-leveling.tolerance 0.03 # the probe tolerance in mm, anything less that this will be ignored, default is 0.03mm
#leveling-strategy.three-point-leveling.probe_offsets 0,0,0 # the probe offsets from nozzle, must be x,y,z, default is no offset
#leveling-strategy.three-point-leveling.save_plane false # set to true to allow the bed plane to be saved with M500 default is false
Panel
Network settings
Hi arthurwolf - just a followup - thank you for your advice, I was able to get the corexy movement working properly by running through all the combinations of motor connections and orientations (of course the one that worked was the last one I tried):
alpha beta
M1 forward M2 forward
M1 forward M2 backward
M1 backward M2 forward
M1 backward M2 backward
M2 forward M1 forward
M2 forward M1 backward
M2 backward M1 forward
M2 backward M1 backward
The servo module is now working just fine as well. I should’ve spent more time troubleshooting on my own before posting, Thank you for your advice, and for supporting those of us that like the smoothy.
Brian
