Stepper / driver woes
How are you guys? Again I’ve been away for a while, got some time to jump back onto things and I’ve been trying to troubleshoot a x/y axis problem I’m having - I have ruled out mechanical issues as it is almost the same problem at 10mm/s as it is at 100mm/s (and the mechanics are really beautiful).
The problem is I’m loosing steps, repeatable each time I print the same part, I have a hunch this is ‘stepper high delay’ related or similar firmware issue.
I’ve narrowed the missing steps down to this:
Parts that involve a lot of XY detail are FINE.
Parts that involve a lot of E retractions are the culprit.
What settings do you guys use for your machines (I’m specifically using repetier firmware v.92)?
Keeping in mind I’ve CNC machined most of my components from oh-so-heavy (but oh-so-shiny!) aluminium, I have reduced the acceleration to 1000 (have had it as low as 500 trying to sort this out with no positive results). I have jerk set at 5 and I have reasonable microstepping (100steps/mm).
I’ve used the A4988 and DRV8825 drivers, both had issues, and I’ve since grabbed a few wantai DQ420MA drivers which give me much smoother, more powerful operation but, freak out when e retracts…
The loss of steps is EXTREMELY small, I can do things like vases that have no retraction and have no error, but noticed it when I started printing some lettering and with 8+ retracts per layer it started skewing. It’s an almost perfect skew, not random in any way, so I’m guessing it’s loosing the same steps at the same point on each layer. If I rotate the model 90 or 180 degrees the skew follows it. If I change the start point of my loops from front left to rear right the skew changes direction with that. (might be a hint - printing the word “Techne” it prints from left to right so, 6 retracts where it moves right immediately after and only 1 retract where the move is in the opposite direction)
I see for ‘gantry systems’, we do need a stepper high delay (according to repetier firmware setup) and I may also need to increase ‘stepper direction delay’ and ‘quadstepping delay’ but I’m not sure where to start.
Anyone have any issues/tips/information about movement / steps / firmware?
