Stepper motor issue
I just recently added a smoothie board to an Atom 2.0 and are having stepper motor issues. I found a video specifically setting up a smoothie board to an Atom 2.0 Delta printer and followed the directions to a T. When it came time to test everything out i found i couldn’t jog the stepper motors independently. Using Ponterface i went to jog the X motor 10mm to ensure it was moving the correct direction and noticed all 3 motors reacted. Then trying to home all 3 they just shuttered and it faulted itself out causing me to have to reset the board. I have the current for each motor set at 1.0, and the homing set to delta so they should all move at once but nothing happens. The main concern is when in Ponterface if i try and jog the Y the X trys to move, if i try and jog the Z the X trys to move, and if i try moving the X they all react. Im fearing the drivers are bad but im hoping ive overlooked something simple. Any help is appreciated.
