I previously posted about missed x/y steps with no response.
My printer never missed any steps prior to upgrading the firmware and enabling grid leveling. Since then, I’ve had nothing but trouble.
I’m seeing some *very* weird behaviour going on….
The first time I saw the missed steps was directly after I set up the bltouch and grid leveling. I then turned grid leveling off and tried again which resulted in missed steps again. I then turned grid leveling back on and it would not level. I could see the z motor making adjustments to the height, but the nozzle would still crash into the back of the bed (but not the front). Upon further inspection, I could see that the leveling was making adjustments while the nozzle moved in the Y direction, but then at the end of the Y movement, the bed jumped back to it’s original z location. And then upon starting a move back to the original Y location, just before the move, the z would suddenly jump down to where it should have been and then make it’s slow adjustment/correction. I have a video of this, but I can’t post links but I’ll try: photos.app.goo.gl / A7JINLwAv5nhicA62
And there’s even more weird behaviour going on with the z too. This is with grid leveling cleared and off. M375.1 returns all NaNs. If I home all axis (z homes down/away from the nozzle, corexy), and then move up to a probing location and run G30, the first time I get 1.9mm, and all subsequent times, i get 2.4mm. This is 100% reproducible. So I figured, something must be loose with the bed such that when it moves down after having just moved up, there’s play/slop/backlash. So the next test I did was to move to the probe location and first do an up-down z movement before the first probing. This test ended with the same result: First probing is always 0.5+mm closer to the bed. It also makes a very funny noise when moving x and z simultaneously but sounds smooth when moving one at a time. I’ve verified that smoothie is actually moving the z motor to a different location after finishing the first probe. I have a video of this as well. You can also hear the weird sound the motors make when it tries to move both z and x at the same time.
photos.app.goo.gl / 6UbMf2uAQ0CHBhht1
I’m pretty lost at this point…
