Still trying to find a good program for making timelapse videos.
Still trying to find a good program for making timelapse videos. I’d like to know what others are using especially if they are huge! like 500+ pics.
Are you looking for a program to periodically snap pictures from a webcam or for something to combine those pictures into a video?
I use premiere pro, when I import my 7000+ images from an over night timelapse, premiere has an option to import numbered images, which is them imported to the project timeline as a nice video compilation, all I do is set the speed, then export & re-import to a new sequence…
test here… https://www.youtube.com/watch?v=bcN9Gxuv5LE
You may find that any reasonably well written video editor will handle your photos. 500 photos at 24 frames per second (old-style film rate) is slightly mroe than 20 seconds of video, hardly a struggle for a decent program. You may also find some free alternatives, especially if you’re using linux.
If they’re in order and you’re not giving them weird random filenames, then do it with command line!
http://www.mplayerhq.hu/DOCS/HTML/en/menc-feat-enc-images.html
I’ll use ffmpeg command line : http://hamelot.io/visualization/using-ffmpeg-to-convert-a-set-of-images-into-a-video/
I’m not trying this in linux. Windows application please. actually I was having issues with some other programs because of the naming method. I named the files Date/Time(Seconds).JPG
EX: 2016-03-31_0225.jpg
ffmpeg works nice in windows, too, mplayer, I think, has also a windows version :slight_smile: But the naming could make that difficult…
Actually @Volker_Klaffehn the problem with ffmpeg was that it doesn’t take in all the files. The final movie was missing like half of the files.
You could download the Windows version http://mplayerwin.sourceforge.net/
Or just run Linux off of a live CD and process your pictures from a USB drive?
Thanks @Francis_Lee Yes I am using a Raspberry Pi for the pics and all the pics are set to be saved on the USB stick. So all I have todo is remove the stick and plug into my lappy.
Ohhh… hmmm I wonder if there’s a way to trigger a script to create the video right on the raspberry pi when the print is done??? :slight_smile:
Actually I’d like to process them myself so I can preview it and see how well the quality is and how fast it is. So that I can adjust accordingly.
Magix Movie Edit will do it and there is a trial. Before you import set the standard picture length to 1 frame and it can handle an absurd number of images without chugging down.
You could do the whole process on the Pi. http://rasterweb.net/raster/2013/09/06/tlbot-4-camerapi/
