Stop print with no any visible reason.
Tested on version V1.25
I four time print exactly this same GCODE generated with Slic3r
https://sites.google.com/site/ithink3d/wydruki-3d/schody
two times printed with no any big problem … but sometime “frozen” for few second and continue
then I try to print VASE - print stop after 5% https://sites.google.com/site/ithink3d/wydruki-3d/waza-1 but think this is problem in g-file…
Then I try print STARIRS again … but t totally stop after random time … with no any report problem on CONSOLE.
Then I reboot TABLET and switch off WIFI … ( for block background mail check and other google activity )
This same problem - print stop
I test exactly this same g-code on few different ABS filament and few FAN cooling settings… then I’m shure that G-code file is ok because two first time print OK …
problem is with APK 1,25 or Android… Teensylu-Marlin works OK with no any hang with PC
Maybe on version 1.26 will be better
this must be something else…
