Strange movement after every line
Hi,
I noticed that, after cutting a straight line from top to bottom, the laser stops and the head moves a few mm to the left. before starting the next line. It catched my attention while cutting a pattern to create flexible wood. It doesn’t affect the outcome but it’s time consuming for no reason.
Is there a solution for this?
Thanks,
Jos
No one replied… but I’m seeing the same behavior when creating an envelope that has perforated dashes.
The same issue has been discussed here :
