These are the settings in my config.txt:
switch.psu.enable true
switch.psu.input_on_command M80
switch.psu.input_off_command M81
switch.psu.input_pin_behavior momentary #probably not required
switch.psu.output_pin 1.27ov! # Y_Max Endstop; tried all options and combos: open drain, pull-down, inverted to no avail. Maybe pin is missing capabilities??
switch.psu.output_type digital # on/off only
should I use analog (pwm) instead of digital? Any ideas, pointers?
