Taking my desk-decluttering to the extreme, is anyone aware of a 3D printer design that’s made to hang from the underside of a high desk, rather than it take up desk space? (I use a standing desk and bar stool when I want to sit)
Most of the time it’s either sitting idle, or being left to do a print for hours.
Deezmaker’s Bukito (and other designs) has been proven to work in any orientation and position - just mount one to the the bottom of your desk upside down?
By the way, I’m doing the exact same thing with my desk! Unintended side effect: The bar stool gets annoying after a while and encourages you to get up and stand or take a break every now and then!
Great aren’t they, I wish I’d used a standing desk years ago. It’s doing my posture a world of good.
A Bukito bolted upside down? If astronauts can print in zero G why not turn one on it’s head I guess. It could have other benefits - when the bed cools the print falls off ready for the next one
@Mark_MARKSE_Emery but those print failures that prematurely knock off a print would become potentially catastrophic. Rats nest wedged into the gantry.
Have you considered going up? A while ago an engineer friend of mine had a set of bench test tools (oscilloscope, dvm, and signal generator) that were on a shelf that he pulled down from the ceiling when he needed them and pushed them back up when he didn’t. They were on a weighted block and tackle that made the shelf “zero” weight.
Well, should you get a 3D printer, print out and design some under-table hooks! Practically any 3D printer could be hung under a table with the right hardware.
A Bukito can easily print upside down, but it would be pretty awkward removing prints that way. If you’re using a sharp tool, awkwardness can mean injuries. I would be more inclined to attach hooks to the bottom of the desk and hang the printer from the convenient carry handle.
Of course, a more practical solution might simply be to put some shorter shelf or table-like piece of furniture under the desk for the printer to sit on. Using something portable like a Bukito would still allow you to move the printer to a more comfortable height for things like removing prints, changing filament, and any maintenance that might be needed.
