Telnet
Hardware: Re-Arm Ramps 1.4 with network
when setting up repetier host using tcp/ip ip address : port 23
I can control the printer home, move, turn on hotends and bed with out much of a problem.
When I try to print it homes NP starts to print then shudders smooths out on layer 2
any ideas
Seems the slicer I was using was the problem.
I sliced the model with cura and everything worked.
I did have to increase the cache size from 147 to 2096 in printer connection settings
