Hey all im wondering if anyone can help me figure out what would make sense todo next. I am seeing a 3-7 degree drop in temperature while printing which varies depending on the model it seems. Setup consists of an E3D volcano with .8 nozzle on smoothieware at 1800mm/min with 2 blower fans cooling the print and an E3D fan cooling the nozzle, 40W heater cartridge
What ive done
-PID autotune: I have done an autotune with blowers on at full blast giving me P41.0 I2.615 D161
-Hotend is insulated with heatsleeving and kapton tape
-Using a E3D cartidge thermistor (assuming that this has exactly the same profile as the old style E3D thermistor as that’s what its enabled as in the smoothieware configuration right now, not using a beta value)
-Slowing down the print: even at 1800mm/min, .6 layer height and .8 layer width (19.2mm3/sec) which is a lot lower then the possible 45mm3/s
