Well my printer is working well and getting reliable prints. The only issue that I am having is reaching extruder temperature.
When I set temperature in Pronterface (by entering value and clicking button) the temperature hits the right temperature.
If I use my Astrobox and either manually use the m104 or m109 command the temperature never hits the target temperature. It gets within 1C at best.
I have double checked my thermistor settings in config (Semitec) as I am using an E3D.
I have also done PID tune and entered values into the config.
Something wierd is happening here as pronterface has no issues getting to temp. I dont have an LCD display on my unit so cant check there
