Test pieces from the wood burner,
Test pieces from the wood burner, depending on the tip it can produce very flat burns or very deep V shaped ones.
WOW! That’s amazing. I am amazed this worked.
I would imagine that it depends on the speed the tip is moving, the temperature of the tip and the type of wood being used.
Very similar to a laser engraver / laser cutter.
