Testing 0.2mm nozzle.
Just saw that E3D says on their site that you have to use the 0.15mm nozzle with their silicone sock, or there will be too much heat transfer from radiation
I love the detail you can get with a 0.2mm nozzle. I find that I have to increase the temperature with each smaller nozzle size by about 5 C and compensate for over extrusion to a greater degree. Radiant heat can become a problem and multiple objects help things stay cooler.
So is that aluminum foil or aluminized tape in the 4th picture? Just curious what it’s used for
@Alex_Krause Tape. Had a PC fan blowing on the print and had to shield the hotend …
