Thanks to this community in general and +Jeremy Spencer and +Jason Coon specifically (for
Thanks to this community in general and +Jeremy Spencer and +Jason Coon specifically (for helping sort out my code issues), my project helped make Boston Pride a little brighter. https://youtu.be/9bVN3PuzrsI
Awesome, that turned out great.
What battery did you end up using?
@marmil RAVPower 6000mAh External Battery with iSmart Technology (2.1A Output, 1.5A Input) https://www.amazon.com/dp/B00OZM8PEW/ref=cm_sw_r_cp_api_viSxxbAJ824WD
Fantastic, well done :slight_smile:
Awesome work
@Jeremy_Spencer thanks and thanks again for all your help!
@Leon_Yuhanov thank you!
@marmil I’ve discovered that one of the great things about designing for drag performers is that you can hide big batteries and controllers in the boob region :stuck_out_tongue_winking_eye:
@Charity_Stolarz ha, well of course!
We’re going to need a bigger battery.
this is great! How did you guys end up controlling the unit?
@Randal_B it’s controlled with the adafruit Bluefruit LE Connect app. We had it on my iPhone and her android. It worked great but we ran into some issues at the club when it was picking up hundreds of other BT signals. The link for the code is in the YouTube description
