That has to be the simplest, most printable 3D printer design out there. Very minimal extra hardware required. Just nuts, bolts, bearings, 1/2-10 lead screw and couplers direct to the motor shaft. Fast movements currently up to 300mm/s. Requires some tweeks to the firmware to compensate XYZ to rotational movement, but that seems to be working already. Let’s hope he releases the files soon.
zac, the files aren’t even released yet, so there is no way to know the actual total price, but I would imagine it would have to be one of the cheapest possible printers. The lead screw, couplers, nuts, bolts and bearings are probably $20. The 3D printed parts are free if someone likes you up to maybe $100 if you have to go to a company. The motors and electronics are the bulk of the cost. What can you get 4 NEMA 17 motors, and a RAMPS for these days?
I’ll try to answer some questions.
It is a 90:1 gear ratio which was arbitrarily chosen. The entire project is parametric including the worm gear
Printed in PLA
The heat sink is threaded and is being used as a nut to hold the effector together, it looks strange at the moment I’ll agree but I wanted to focus on getting the movement working.
Nice and simple. But how do you keep the extruder exactly vertical. If its vertical only by pulling from the axes, then my guess is, that there is quite some calibration to do.
Apparently that threaded rod was machined to make it fit the motor shaft, rather than being attached with a coupler. That makes it a bit more difficult to home build… Perhaps there is some other way to make that happen?
Henrik, as I understand it, it’s basically a 3 legged version of a pantograph. The hot end stays vertical. There is some software work to translate the X Y Z coordinates of standard G-CODE into the rotational position for the motors and gears, but that code appears to be done and ready to hack into the controller.
