The breadboard version of the current version of my led staffs,
The breadboard version of the current version of my led staffs, with gesture driven “buttonless” interface. This keeps water and dirt out, as the whole thing is in a gasket sealed tube
http://youtu.be/39jM_a94kUs
Pretty neat. I wanted to try that with the ADXL345 but I got side tracked doing other stuff. Which sensor are you using?
Adxl345, the same one. Board has that and an itg3200 gyro and a hmc5883l magnetometer. I had a board that had MPU 6050 and the HMC 5883L but ended up buying and making a mistake on all express and ended up with the 80 XL
I have an LSM9DS0 from SFE that I’m going to play with. It’s a single 9DOF IC that also has single and double-click detection. Should be fun to play with. I just haven’t had a chance yet.
Correction: I made time to play with it … just now. :slight_smile: Accel, Gyro, Mag … all working. Click/Double-Click aren’t configured in the library so I’ll have to do that myself. Still, it’s a fun little IC, 4x4mm with a few capacitors. Plenty of room for something like that.
I forgot it also needs to be paired with a TXS0104 open-drain/push-pull IC, though that too is relatively small at 4x8mm.
I wish you guys would stop showing off these cool things, you’re killing me. :wink:
It’s a trap Adam. We’re just luring you to it.
It’s working @Ashley_M_Kirchner_No trust me
@Ashley_M_Kirchner_No you only need the TXS0104 if you’re running a 5V level device, with a 3.3V level device, like the teensy3, no worries. But you’re going the fully integrated route where I’m going a slightly different route.
Exactly, I run my uC at 5V. The LSM9DS0 is a 3.3V device.
