The current beta of has Macro support. Up to 5 Macros can be defined.
The current beta of gcodeprintr has Macro support. Up to 5 Macros can be defined. I would like to have some sensible default pre-sets.
Any suggestion for predefined macros ?
Bed leveling macro with pauses at each point.
To use after a pause: retract, move the hot-end to a corner for filament change, disable extruder motor.
@Deven_Garner I have no idea which gcodes are needed to do bed leveling. Can you provide me a macro that I can use ?
@Andy_W You can already home all axis by long pressing home-Z button. I’m not sure if you save much by providing a macro given the fact that you can do home+temp with 3 clicks with the existing controls.
Hard question, being thst the whole point is to add functions that don’t qualify as “standard”…
Hmmm…
Could make one “set home here”, one “set x y z e acceleration”?
