The fastest initial PowerMac was an 80MHz 32-bit RISC machine that cost $4,200.
The Teensy3 is an 84MHz 32-bit RISC machine that costs $19.
And of course, the FastLED library supports the Teensy3, making it obviously the better choice.
If you were to add up your countless hours developing the library, and apply a per-hour charge, I’m pretty sure you will go well past that $4,200 …
