The NiMH cells continue to preform, despite unpleasant cold. 3 AA cells versus an ESP-12F, active for 60 seconds every 5 minutes.
This test has been running since Feb 3, and the last voltage reading was 3.6v at -8.5°c.
Hello, can you share schematic and code which you use in this experiment? Thanks!
Hello @Alexander_Ribchansky I will put the schematic and code here: https://github.com/gordonthree/batTemp
I’m at work right now, and the code is at home, check back later and I’ll post it up.
Thanks! Will checkout schematic as soon as reach my notebook with eagle;) will wait for code either!
I have uploaded the Arduino sketch I’m using.
This is really interesting work, thanks for sharing it with us. Can I ask how you measure the voltage on the battery and input this measurement to the esp?
Hi @Stefan_Nordlander . I am using the built in ADC routine, ESP.getVcc() to read the voltage on the Vcc pin, which is also the battery voltage. You can divide the number by 1023 to get a more exact voltage, or just count the reading as millivolts.
On another experiment, I put a 10K0 + 2K2 voltage divider across the battery terminals, and attached that to the TOUT pin (ADC / AN0). 10k0 + 2k2 gives handles a maximum voltage of 5.545 volts scaling to the 0-1v range.
@Gordon_McLellan Thanks alot, did not know abot that function. It was very helpful indeed.
