The “outline” function in LaserWeb really helped center this Abalone shell piece in the right position. 50℅ power. 20mm/s.
Another cool feature could be a button to move the head to the center of the bounding box.
How can i activate my Diode-Laser with this Function??
thanks for your help
@Cai_Kaktus I’m not sure about the settings for a diode laser. But I used LaserWeb to process the graphic for rastering it Into this material. The power level I used was about 15 watts
Thanks for your Answer.
I use Laserweb for the same things like you.
But when i use the “outline function”, the Laser is not in function.
so i can not set my object in the right position because i can see nothing.
the head is moving, but without activated laser at minimum power…
@Cai_Kaktus ah I see now. I’m not entirely sure but I think in the config file there is a setting for tickle power. I think that is so you can turn the laser on at minimal power while moving so you can see the dot but not burn anything. I have red line laser generators on my laser head.
