The pressure sensor for the TLPHnodeV2 is also light sensitive.
The pressure sensor for the TLPHnodeV2 is also light sensitive. So while I’m not ready to commit to a full enclosure I do need something to test with. I’m having a mount 3d printed. The 3d model of the PCB was exported from KiCAD and then imported to FreeCAD so that I could visually check for interference problems.
http://sensornodeinfo.rockingdlabs.com/blog/2017/01/16/mount/
Hi, how did you export the 3D from Kicad to FreeCAD?
The KiCAD export is from Pcbnew. File->Export->VRML. Set the X-Ref/Y-Ref to a corner of your PCB.
Import to FreeCAD is also under the File menu: File->Import…
Thank you Jerry, I was looking for this feature before without success.
