The stock I use primarily for cutting is 3mm birch craft plywood.
Does anyone have recommendations for stains, oils, or finishes which work especially well with this wood?
I pretty much use Minwax products. Use a pre-stain if you are staining.
For stain I recommend the Minwax products as well. The birch I’ve used hasn’t required a pre stain personally. Just don’t sand below 200 grit before hand. For finishes on birch ply I typically like to use lacquer and sometimes polyurethane.
@Nedman if the wood is good quality the pre-stain may not matter and the results not blotchy but I do it just to be safe since wood quality these days is so unpredictable.
