The video is rather long and the support material is excessively strong.
The video is rather long and the support material is excessively strong. You might find it interesting nevertheless.
Originally shared by Richard Gain
Support removal on a complex 3D printed part.
https://www.youtube.com/watch?v=pwPhe2azpCo&feature=autoshare
I admire your patience. I would have destroyed that fragile-looking thing.
Don’t watch the videos on http://mendelparts.com where it just breaks away easily.
You should try Cura @Richard_Gain I found it produces a much better support structure than Slic3r. It’s only down side is that (at present) you can’t alter the support angle threshold but it’s due to be included soon.
@Daniel_Fielding - I do find that support on the side of a print, like the blue owl had, is generally much easier to remove than support material that lies under a horizontal beam.
Agreed, @Tim_Rastall , Cura is getting better and better. I often end up slicing objects in multiple slicers and then inspecting the Gcode in Repetier Host to decide which version to print.
if you really want to drive yourself crazy, try removing the supports on this: http://www.thingiverse.com/make:41825
