Thermistors read constant, even if disconnected
My thermistors always read this, even if I disconnected all three thermistors from Smoothieboard. What is the problem? Thank you
M105
ok T:122.1 /0.0 @0 T1:122.2 /0.0 @0 B:131.9 /0.0 @0
M105
M105
ok T:122.3 /0.0 @0 T1:122.3 /0.0 @0 B:132.1 /0.0 @0
M105
  1. Hotend temperature control configuration
temperature_control.hotend.enable true # Whether to activate this ( “hotend” ) module at all.
temperature_control.hotend.thermistor_pin 0.24 # Pin for the thermistor to read
temperature_control.hotend.heater_pin 2.7 # Pin that controls the heater, set to nc if a readonly thermistor is being defined
temperature_control.hotend.thermistor Semitec #
temperature_control.hotend.designator T #
  1. Hotend2 temperature control configuration
temperature_control.hotend2.enable true # Whether to activate this ( “hotend” ) module at all.
temperature_control.hotend2.thermistor_pin 0.25 # Pin for the thermistor to read
temperature_control.hotend2.heater_pin 1.23 # Pin that controls the heater
temperature_control.hotend2.thermistor Semitec #
temperature_control.hotend2.set_m_code 104 #
temperature_control.hotend2.set_and_wait_m_code 109 #
temperature_control.hotend2.designator T1 #
temperature_control.bed.enable true #
temperature_control.bed.thermistor_pin 0.23 #
temperature_control.bed.heater_pin 2.5 #
temperature_control.bed.thermistor Honeywell100K #
temperature_control.bed.set_m_code 140 #
temperature_control.bed.set_and_wait_m_code 190 #
temperature_control.bed.designator B #
This looks like the thermistors are absent even when connected.
Could you try connecting a 10K resistor across one of the thermistor inputs, and see what it reads ?
Thank you for your response!
When I bridged it with an 11 K ohm resistor, my voltmeter read 2.18V.
(When T0 is open, the voltmeter reads 3.11V)
The output from M105 did not change, however.
Pulled the board out of my printer today to put under scope.
When plugged into USB for power, the V across T0 (while T0 is open) is 3.04V. Is this typical?
I flashed the latest edge build date Apr 28,2015. There is nothing plugged into Smoothieboard except USB. I reset the config file to the original. I had a strange result:
With hotend.thermistor_pin = 0.23,
M105 responds T:125.6 /0.0 @0 B:129.1 /0.0 @0
When I modified config to set hotend.thermistor_pin = 0.26 and reset,
M105 responds T:250.1 /0.0 @0 B:220.1 /0.0 @0
Could this be indicative of any particular problem or broken components?
