Thermocouple with the X5mini
I am trying to get a thermocouple working on my printer that runs using an X5 mini controller and have been running into a few issues. I can’t get my X5 to recognize that I have anything connected to it. I am using the MAX 31855 breakout board with a type K thermistor that was suggested on the website and I have it wired up like this.
Max31855 X5 mini
Vin —> 3V3
Gnd —> Gnd
DO —> SDA
CS —> 0.26
CLK —> SCL
I am not one hundred percent sure that this is correct so any suggestions are welcome.
Now my config file looks like this:
#Hotend temperature control configuration
temperature_control.hotend.enable true # Whether to activate this ( “hotend” ) module at all. All configuration is ignored if false.
temperature_control.hotend.sensor max31855
temperature_control.hotend.chip_select_pin 0.26
temperature_control.hotend.spi_channel 1 # SPI channel 0 or 1
temperature_control.hotend.heater_pin 2.5 # Pin that controls the heater
temperature_control.hotend.max_temp 300 #
temperature_control.hotend.designator T #
Is there something wrong that anyone sees wrong with it?
Thanks for any help!!
ok SPI channel needs to be 0
temperature_control.hotend.spi_channel 0
and you have it connected to the I2C not the SPI port so…
DO —> 0.17
CS —> 0.26
CLK —> 0.15
that will work
Thanks! I got that to work using that setup. I had to disconnect my LCD screen though. Do you know of any way to set it up so that it will work with a screen hooked to the SPI too?
