thinking of upgrading the lens to 20mm instead of standard 12mm lens for one because the air assist is actually on the laser head built in would i need to upgrade the mirrors to do this or could i use the ones i already have and would i get more power with upgraded lens any help would be great
You can use the mirrors you already have. The bigger lens is less susceptible to misalignments.
However upgrading your mirrors from the stock mirrors would most likely increase power throughput.
thank you very little info out there so glad i joined this forum
