Looks interesting, what are the problems you see with using threaded rods? Except for possible speed problems it looks ok to me. But then I have not built a Rostock yet.
I have a theoretical max speed of 240mm/s as drawn so if I could get 1/3rd of that I will be happy. Backlash is the other possible problem but if it is a problem I have a few ways I can 3D print wear compensating nuts.
Very cool, especially considering this was a penance exercise. I do agree that you probably should not use rods. You probably would not have backlash unless you accelerated fast enough to generate enough inertia to offset gravity. The wear would become an issue as you stated, bit then again, the wear doesn’t affect the pitch, only the backlash, but you accommodated for that. Very cool, nice work
The problem with spinning threaded rod is getting it ideally straight.
If, however, you make the threaded rod only for vertical movement and use smooth guide rods (or extrusion, etc) for straight movement, then that problem is solved.
@Nicholas_Seward But what about Simpson? Still waiting for the files there! I really want to build one, and you’re starting on new designs? You’re killing me here!
Looks cool, actually. To what extent is it an improvement over the Simpson?
@Patrick_Ryan I know. I know. Consider this a warm up to get me in the mood. (As you may or may not have noticed, there has been a dry spell of content from me due to outside forces and now I am gearing up again.) I had great plans of locking myself in a room this weekend. I am already foiled. I having to take my cat to an emergency vet clinic.
I don’t think LISA is better than GUS Simpson except for build simplicity and build volume.
@Nicholas_Seward Oh, I noticed!
Ok, so Lisa has better build volume - pretty much unlimited vertically, I guess - but you need high quality threaded rods, right?
