I have heard you can burn up components that way. Thermistor shows a lower temp than it actually is and so it throws too much heat at the component and burns it out.
@William_Frick be careful, that E3D can get hot enough to melt aluminum. That’s why I fire cement my thermistors in place. Now, if a thermistor goes…that’s going to be hell.
Woah I had no idea that it can get that hot! Can you confirm by hand if it indeed isn’t heating? What is the resistance of the heater? It should be low (less than 100 ohms for sure id think)
After that it dropped to ambient. It doesn’t heat anymore. I was under the impression the resistance would be huge, it is converting all the power to heat.
@ThantiK Probably could but not nearly as quickly. The active cooling would slow it somewhat. Besides that episode cost me 3 +weeks of printing and I am determined not to let that happen again !
Is it likely I’d find self vulcanizing tape locally? (I’m amazed at the little fiddly odd things these printers take that can’t be sourced locally easily. )
@Mike_Miller Mine is from UZ Engineered Products. http://www.uzengprod.com and is called ‘Wrap n Roll’ . They are in Cleaveland OH. It is rated to 260 C and so far is holding well. Try getting a EPCOS thermistor in Canada ! Almost everything is an online store somewhere else .
Pulled the extruder assembly apart…one of the wires wasn’t well soldered…so, that’s cool, I can fix that for free…but the collar for the ‘J-head Groove Mount adapter’ delaminated. <grrr.> I’ve got an email into the guy I bought the printed parts from…I’m also considering looking up anyone in South Denver that could print an STL for me…
