This is going in the OPPOSITE direction that most folks want…
But has anyone found a “dumb”(ie single color) led strip in LESS than 30 LEDs/M?
I have a 100m run that doesn’t require much lighting so “30/60/120”/m is overkill.
Try some of the pixel “node” strings, maybe?
Eg http://m.aliexpress.com/search.htm?sellerAdminSeq=109417280&keywords=node
I like these compact 3 LED injection molded modules because they are durable and can be arranged in a tight grid with no space between modules or cut and used individually or cut and further extended between modules to cover a longer run.
http://www.aliexpress.com/store/product/HOT-Black-PCB-20pcs-lot-SMD-5050-3-LED-20Lm-LED-Module-RGB-Waterproof-IP65-DC12V/638265_1979080395.html
