This is probably a dumb way to do this but it seemed like a simple/easy way.
I am trying to check if the color of led[i] == someColor then change the color but the compiler doesn’t like the way I’m trying to get it to work. Does anyone know of a way to get something like the example below to work? Hopefully G+ doesn’t butcher the code too bad, I don’t think this tiny amount of code warrants a gist.
@Christopher_Kirkman1 Well shoot, that’s what I was trying but it doesn’t work. I only used the struct name to make the example easier to understand. The error that the compiler throws is “ambiguous overload for ‘operator==’ (operand types are ‘CRGB’ and ‘int’)”
The error makes sense and I understand why it doesn’t work. Just hoping someone knows a way to do what I am wanting.
@Gibbedy_G Thank you! I tried this way first since it seemed simpler than the other solutions and it worked great. Thank you to the others that also chimed in. It’s always interesting to see how other people would solve the same problem.
