this is the future ! (or at least I will try to see how it goes)
http://reprap.org/wiki/File:FoldaRap-Mondrian_RackPinion_03.jpg
Timing belts are in essence the same thing as rack and pinion, they are simply cheaper to get precision parts made than rack and pinion. Regardless, I’m sure you’ll discover some excellent findings in your research. Please be sure to post your results. Good luck!
True
In fact I’m even using belt as a rack for the moment, but since I’ve seen some printed rack& pinion by pacmanfan years ago ( http://www.thingiverse.com/thing:8938) I wanted to try to print them too. Replacing the belts already integrated in the aluminum profile of my repraps will keep things neat ^^
hmm… I don’t think it’ll be precised enough! Let you know
I’ll post picture of the experiment, we’ll see
@Hugobiwan_Zolnir tu va aimer ce nouveau détail : http://youtu.be/MtifasBHbDE
(adjustable x-slider) / I’ve several videos to post, the rack&pinion is working nicely ^^
Intéressant !
ok, more videos now ! (and more to come as they are two weeks old ^^)
