This is the work that i’ve been doing(SparkFun FTDI Basic Breakout – 5V).
Even though I did auto level at every 2 step,there are some traces missing and I couldn’t get even depth.I used Zcut=-0.05.
In my machine Z axis axis movement is controlled by M8 threaded rod and I know some machines use ACME. SO is there any way to change Z axis parameters.
I don’t know if this is do wrong Z axis parameters
V bit 0.1mm 15 degree
I tried once again by increasing depth to -0.08 but still I couldn’t engrave someplaces even though i did auto level. Don’t know why
It looks awful. It seems that no auto-levelling worked and given your past posts it did sound like your probing was failing you. Have you ever gotten even the simplest of probing to work? You up for making a video so we all can better help?
yeah, i agree with the video… also, if your x-carve is having general issues, you will be much better off posting to the inventables forums than to Chilipeppr.
right… so what I’m suggesting is that you can run probing anywhere… if you run the same GCODE to do the probe in any GCODE sender, and it doesn’t work, then you will want to post that on the inventables forum. If the GCODE works in other gcode senders (like UGS), but doesn’t work in Chilipeppr then I would suspect a problem with Chilipeppr.
