This is what happens when I G29. Movement works in all directions now, I rewired to have both z axis on same stepper driver.
How do I adjust the speed the movement is for probing?
Why does the x axis move when probing instead of the Z?
Ah, that might be a bug actually. It thinks it’s a delta when probing so it switches to Cartesian coordinate system and travels the same amount in x,y,z which on a delta is only z.
Do all axes move when probing or just x and z?
For me all axis are moving and I always get more or less the same offset for all points, however I definitely messed up my leveling by placing a aluminum plate at one of the probe points.
That’s wat I see on the console:
Recv: Found Z probe height 0.009 at (X, Y) = (10.0, 20.0)
Recv: Found Z probe height 0.009 at (X, Y) = (10.0, 160.0)
Recv: End stop Z2 hit!
Recv: Found Z probe height 0.009 at (X, Y) = (170.0, 100.0)
Thanks,
Christian
@Elias_Bakken You were right, the file PathPlanner.py needs to be patched
Line 298 and 327 have to be changed from:
end = (-z_dist, -z_dist, -z_dist, 0.0, 0.0, 0.0, 0.0, 0.0)
end = (z_dist, z_dist, z_dist, 0.0, 0.0, 0.0, 0.0, 0.0)
to:
end = (0.0, 0.0, -z_dist, 0.0, 0.0, 0.0, 0.0, 0.0)
end = (0.0, 0.0, z_dist, 0.0, 0.0, 0.0, 0.0, 0.0)
However, this is only true for Cartesian, not sure if this will work with Core XY.
Now auto bed leveling seems to work for me, but I’m still testing.
Edit: It works, here is my G29 macro for a Prusa I3 with an inductive probe as a reference in case somebody is interested
[Macros]
G29 =
M561 ; Reset the bed level matrix
M558 P3 ; Set probe type to Servo with switch
M557 P0 X10 Y20 ; Set probe point 0
M557 P1 X80 Y20 ; Set probe point 1
M557 P2 X170 Y20 ; Set probe point 2
M557 P3 X170 Y80 ; Set probe point 3
M557 P4 X80 Y80 ; Set probe point 4
M557 P5 X10 Y80 ; Set probe point 5
M557 P6 X10 Y160 ; Set probe point 5
M557 P7 X80 Y160 ; Set probe point 7
M557 P8 X170 Y160 ; Set probe point 8
M574 Z2 z_neg ; Enable endstop Z2
G28 X0 Y0 ; Home X Y
G28 Z0 ; Home Z
G0 Z8 ; Move Z up to allow space for probe
G92 Z0 ; Reset Z height to 0
G30 P0 S ; Probe point 0
G0 Z0 ; Move the Z up
G30 P1 S ; Probe point 1
G30 P2 S ; Probe point 2
G30 P3 S ; Probe point 3
G30 P4 S ; Probe point 4
G30 P5 S ; Probe point 5
G30 P6 S ; Probe point 6
G30 P7 S ; Probe point 7
G30 P8 S ; Probe point 8
G28 Z0 ; Home Z
M574 Z2 ; Disable endstop Z2
G92 Z0.3 ; Compensate probe offset
G0 Z0 ; Move nozzle to the lowest position
Yeah, just check what the coordinate system is, should be examples of that elsewhere in that file.
Only Z needs to move when probing corexy so I see no problem with the change.
Also, is there a variable that handles the speed of the movement between probe locations? Nothing in the config seems to affect it, and the speed that it is moving, as seen in the video, is driving me nuts.
Is this a file that will be patched soon and rebuilt included in the next redeem release, or do I need to do this to my local build and maintain it myself?
Is there a link to how to rebuild redeem? Or is it simple as editing the file and restarting redeem?
@Philip_Acierto I edit the file with nano directly in the BBB, no compiling needed as it is Python. Unfortunatly I cant remember the path, but you can do
find -iname “PathPlanner.py”
to search for it.
neat, no compiling? Well that will make things easier then! That should at least get me up and running than, soon as I can figure out the Z probing issue on my other post!
Thanks for helping to solve this issue!
Feel free to fork the Redeem repository ( Bitbucket ) and contribute a fix! I was going to do something about it but I don’t have a Cartesian bot to test it on.
Try using:
http://pastebin.com/raw/saPpU6Nv
This just does what was posted above but does a check for the different axis configurations. I am assuming that CoreXY and H-bot would be the same as Cartesian as the Z-axis is all that needs to move when probing?
That would be correct. X and Y is where all the wonky magic happens for movement on the horizontal plane, but Z probing is vertical movement for the standard Cartesian systems, so the same across the board.
I haven’t had time in the past few days to look at my code or test, but once I get another evening to sit down with it, I would be glad to test the proposed fix out on my CoreXY.
I was just hoping to have the homing G28 for my Z fixed first (separate thread), since that is used as part of the G29.
Once G28 is resolved I can hopefully confirm this fix for G29.
I was trying to find my directories/files for redeem using the find command as Christian Herget directed. find -iname “PathPlanner.py” but I don’t get any results. I am logged in to my BBB with putty. I logged in under root. Any idea what I am doing wrong?
If you installed using apt, it should be in /usr/lib/python2.7/dist-packages/redeem (or something there abouts)
I installed everything with the kamakazi image (Flashed). SO where would I find all the files that redeem operates from? I want to try making some tweeks. Even though I’ll probably screw things up,.
You should find them there!
There Where? on my kamakazi flash disk? or on my BBB?
Well, they are the same, rsynced, so after flashing you will find it in your BBB!
@Tim_Curtis you have to run
on your BBB in the root folder
cd /
this should give you:
./usr/lib/python2.7/dist-packages/redeem/PathPlanner.py
Which is the path to that file.
I haven’t looked again for it yet, I was away this past weekend. I’ll check tonight. I did try that command before but I may not have been in the root folder. I’ll give that a try tonight. Thanks for the info.
@Tim_Curtis , @Elias_Bakken included my patch for the file into the master branch of redeem so it should be fixed in upcoming packages (https://bitbucket.org/intelligentagent/redeem/src/32e265e724151bae60637496fa4cc0f1662bb39e/redeem/PathPlanner.py?at=master).
Yes, you need to execute the find from the root directory.
