This is what the ISS 3D printer looks like.
Originally shared by Friends of NASA
International Space Station’s 3D Printer | NASA
The International Space Station’s 3D printer has manufactured the first 3D printed object in space, paving the way to future long-term space expeditions. The object, a printhead faceplate, is engraved with names of the organizations that collaborated on this space station technology demonstration: NASA and Made In Space, Inc., the space manufacturing company that worked with NASA to design, build and test the 3D printer.
This image of the printer, with the Microgravity Science Glovebox Engineering Unit in the background, was taken in April 2014 during flight certification and acceptance testing at NASA’s Marshall Space Flight Center in Huntsville, Alabama, prior to its launch to the station aboard a SpaceX commercial resupply mission. The first objects built in space will be returned to Earth in 2015 for detailed analysis and comparison to the identical ground control samples made on the flight printer prior to launch. The goal of this analysis is to verify that the 3D printing process works the same in microgravity as it does on Earth.
The printer works by extruding heated plastic, which then builds layer upon layer to create three-dimensional objects. Testing this on the station is the first step toward creating a working “machine shop” in space. This capability may decrease cost and risk on the station, which will be critical when space explorers venture far from Earth and will create an on-demand supply chain for needed tools and parts. Long-term missions would benefit greatly from onboard manufacturing capabilities. Data and experience gathered in this demonstration will improve future 3D manufacturing technology and equipment for the space program, allowing a greater degree of autonomy and flexibility for astronauts.
Credit: NASA/Emmett Given
@NASA_Marshall
@Johnson_Space_Center
@Made_In_Space
#NASA #Space #ISS #3D #Printer #Manufacturing #Additive
#Technology #Equipment #Plastic #Materials tools #Components #Microgravity #Research #Testing #Exploration
Very cool. …NASA…Always going forward. …
