This might sound like an odd question,
This might sound like an odd question, but do you think a rapberry pi could handle running both LaserWeb and Chilipeppr which uses just the SPJS running in the background. Wondering if one board could run both machines.
There probably would be timing issues running both at the same time.
I can’t see where I’d ever be running them at exactly the same time. I’m just trying to cut down on the number of computers/keyboards/etc… in the shop. I figure a script to spin up or the other as needed might be an option.
If you will not be running them simultaneously then I day you are OK. Just make sure spjs is not running
BTW AR one point I had my cnc/grbl attached to the same rpi running LW/smoothie
