This program looks fantastic, but I doesn’t seem to connect to my rigidbot. Is there any way to get it working with this printer?
have you changed the baud rate in the app?
yep, I event went through and tried all baud rates, still no luck
and you are using a otg cable?
oh, I was just using a regular cable, didn’t know it had to be an otg one. I’ll buy one and try again, thanks for your help
you can also make one yourself if you don’t mind destroying its “usb” function. take a look at instructables
thanks for the tips. The rigidbot has an arduino in it - it works fine with cura. Do i need to install any special arduino drivers to make thus work?
I didn’t have to
@M_Gol let me know if it works with the OTG cable. If it doesn’t work I will help to debug the problem.
