Thought I would provide an update on the PWM to laser output testing.
As you know I embarked on a task to measure the K40 dynamically at the lasers output.
I built a PWM generator and that works fine as an adjustable source.
I also built a laser output sensor unit that used standard IR sensors like used in remotes.
As you know CO2 lasers operate at 10600 nm the high end of the IR spectrum. I had foolishly hoped that standard semiconductor optical devices (like those in remotes) would have SOME output at this wavelength and if I got the laser power attenuated, I would have a cheap way of measuring the light dynamics.
Nope… no output at the CO2 wavelength. Although one can purchase a lab sensor at this wavelength for lots of money nothing in the available semiconductor technologies have any response this high up.
I haven’t given up. I am now experimenting with some pyroelectric devices which I am not confident will have fast enough response, we will see.
Figured you were wondering what was taking so long :).
Suggestions are always welcome.
