enhydra
(Kurt Meister)
December 20, 2017, 7:53pm
Today was milling day: CAM? With LW4 just a breeze
The milling process worked good. Especially for the grid. But the pig was milled very slow due to all the splines.
At the moment my Win10 is connected to the Arduino grbl 1.1f which talks to the Stepcraft via parallel port.
Can somebody point me to the bottleneck? Is it the USB connection or the Arduino itself or…
Are you getting slowdown on the curves but speed up on the straighs?
enhydra
(Kurt Meister)
December 20, 2017, 9:24pm
3
Add 0.5 to the segment field ( that’s my sweet number ) but make sure you dont see a visual change on those curves. Do I dry test and you will see the difference. Also gcode generation is much faster
enhydra
(Kurt Meister)
December 20, 2017, 9:39pm
5
@Ariel_Yahni_UniKpty Thanks, will try that.
enhydra
(Kurt Meister)
February 2, 2018, 8:35am
6
@Ariel_Yahni_UniKpty Segment 0.5 did the trick. Perfekt and thanks
